Tapo S210 light switch
Hello there
I purchased a 1 gang Tapo S210 switch and was hoping to see it via the Tapo Controller HACS integration. The H100 Zigbee hub shows up fine, but the switch doesn’t, as it’s Zigbee (and I’m pretty sure that’s where my problem lies).
Did anyone find a way how to get these switches to be controllable in HA? I’m not too fussy about response time, so if it takes 2-3 secs response time then I’d be ok with that.
Hi, did you get it to work in the end?
I’ve got these problems right now.
Works great with Tapo App but I can’t get it working in HA although it’s listed over the HACS-Integration.
Greetings from Hamburg,Germany
Hi, late reply, I know. I ended up sending the Tapo back and swapped it for an Aqara instead, which works very well.
