Tasmota discovered but light entity missing
I have a tasmota device that has been auto discovered by home assistant by MQTT discovery but i cant see the entity as a light only as a sensor Status 68%, i have tried it via tasmota integration as well and get nothing at all
i have used Mosquitto broker and never had a problem but this is the first time i have used the Tasmota integration
I had it previously set up in Mosquitto broker and then i backed up and restored the configuration to a different controller, all the colours work in the tasmot web UI
controller flashed with tasmota MagicHome RGB ZJ-WFMN-A V1.1 LED Controller.
TIA
The HA tasmota native discovery integration needs
SetOption19 0 (so19 0)
Depending on your tasmota version eg later than 9.2 the old discovery so19 1 ceases to work.
Which way do you have set option 19 set?
https://tasmota.github.io/docs/Home-Assistant/#tasmota-integration
I had figured it out just as you solved it. yes my Tasmota version was lower than 9.1 now it works in both Mosquitto broker and/or Tasmota Integration.
luckily i was able to update firmware successfully OTA as that we controller is hard to flash
