I’ve got two power strips running tasmota, slightly different models one with 4 outlets one with 3. So I named them FishStrip3 and FishStrip4.
They control various things for my fish tank.
For some reason toggling a switch on FishStrip 4, also toggles the same switch on FishStrip3.
That’s nuts.
How do I go about fixing this? I’ve deleted both devices and done SetOption19 1 on both, then set it back to 0, one at a time, to let them rediscover, but the same problem persists.
No automations or other linking performed.
What sets the devices as unique in home assistant?
Yeah the device names are different but the mqtt page had the same info. Wasn’t sure what % code for the mqtt page should be there to default in the device name
