I got a new sonoff basic, flashed it with Tasmota 9.4.0(lite), connected to wifi, went to its mqtt settings, entered everything - just like I did for other 4 sonoff devices. Then I run “SetOption19 1” in the tasmota console and … nothing happened in HA. Surprise.
MQTTExplorer shows the new device under “stat” with RESULT = {"SetOption19":"ON"}
tcpdump shows trafic from the sonoff device when I do so19 1
. HA has discovery: true
in the config. At some point I switched to the MQTT integration in the webui (or it just got an UI presence? This is a confusing bit) but even there discovery is enabled.
Home Assistant 2021.3.4
How to debug this? What is missing? Thanks,
