Tasmota PowerDelta<x> not working
Following this thread (LINK) I tried to set PowerDelta10 via the webui’s console, but get an error.
20:25:38.708 CMD: PowerDelta10
20:25:38.715 MQT: stat/tasmota_F47F9B/RESULT = {“Command”:“Error”,“Input”:“POWERDELTA10”}
In this thread OP has the same issue. (LINK2)
Any ideas?
From the error, it looks like you sent POWERDELTA10 instead of PowerDelta10
Hello dvdwsn,
I don’t think it is case sensitive.
But since I have not heard of that command before I looked it up. It is fairly recent, so I suggest you check what version you are running, it may not be a command available in that version or possibly not in the build you are using of Tasmota firmware.
I got it working by leaving a space. So “PowerDelta 110” worked to set the delta to 10 watts.
