Hmm the new doesn’t quite match what is in the first post? Looks like some single quotes are swapped for double quotes. Particularly, can you try switching the “off” in the exclude to ‘off’?
No it is the same thing, when I save with single quotes, it becomes dubble quotes automatically.
Weird, mine are single in the UI. I’ll take another look when I can. Probably in a few hours at the earliest.
Is what you posted above the full code for each card?
No, here is the full template of the old version:
And your newest version
All I have done is to remove the media cover because o got annoyed that the photo was always missing (due to HA remote link).
I just copy/pasted in your “new” gist straight into my dashboard, and it works fine for me. It’s only showing a single session.
I did a compare between your version and my gist, and aside from the single/double quotes thing, I see that you removed the picture like you said. I don’t see anything wrong with what you’ve done…
If you inspect the page, go to the console, and then refresh the page - it should print out what versions of custom components you have installed. Do you have the latest 1.13.0 auto-entities installed?
When I check in HACS, it says there thet I have the latest v1.13.0
Could it be some other setting that is enabled/disabled?
Edit: okey I found what I did wrong…
When I added the code to Auto-Entities card, I had this code in the front, before I added your code, in other words X2 of the code below.
- type: custom:auto-entities
filter:
exclude:
- state: unknown
- state: unavailable
- state: 'off'
include:
After removing this, and the following at the bottom, it shows correctly.
I didn’t see this issue/error because the code editor hide the first “custom:auto-entities” so I never saw it untill I pressed manually “show code editor” then I saw it right away that something was off.
Need to see if another button card shows if I have another streamer, but for now it seems that it works as intended.
Thanks though for trying to help me with what could be the issue really appreciate it!
Update: yep, works as intended, thank you for this great card that you’ve done
i have updated the Sensor and the Dashboardcard with the transcode_hw label…
Here is the first template sensor as example…
template:
- sensor:
- unique_id: plex_session_1
name: Plex Session 1 (Tautulli)
icon: mdi:plex
state: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1)%}{{ state_attr('sensor.tautulli_activity','sessions')[0].state }}{%else%}off{%endif %}
attributes:
user: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].user }}{%endif%}
progress_percent: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].progress_percent }}{%endif%}
media_type: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].media_type }}{%endif%}
full_title: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].full_title }}{%endif%}
grandparent_thumb: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].grandparent_thumb }}{%endif%}
thumb: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].thumb }}{%endif%}
parent_media_index: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].parent_media_index }}{%endif%}
media_index: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].media_index }}{%endif%}
year: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].year }}{%endif%}
product: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].product }}{%endif%}
player: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].player }}{%endif%}
device: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].device }}{%endif%}
platform: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].platform }}{%endif%}
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].location }}{%endif%}
ip_address: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].ip_address }}{%endif%}
ip_address_public: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].ip_address_public }}{%endif%}
local: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].local }}{%endif%}
relayed: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].relayed }}{%endif%}
bandwidth: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].bandwidth }}{%endif%}
video_resolution: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].video_resolution }}{%endif%}
stream_video_resolution: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].stream_video_resolution }}{%endif%}
transcode_decision: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].transcode_decision }}{%endif%}
transcode_hw: >
{% if (state_attr('sensor.tautulli_activity','sessions')|length >= 1) and (this.state !='off')%}{{ state_attr('sensor.tautulli_activity','sessions')[0].transcode_hw_requested }}{%endif%}
and here is the code for the card…
filter:
exclude:
- state: unknown
- state: 'off'
include:
- entity_id: '*plex*session*'
options:
entity: this.entity_id
type: custom:button-card
variables:
custom_fields:
picture:
card:
type: picture
image: |
if (states[variables.entity].attributes.grandparent_thumb != ''){
return "https://tautulli-URL/api/v2?apikey=xxx&cmd=pms_image_proxy&img=" + states[variables.entity].attributes.grandparent_thumb + "&width=300&height=450&fallback=poster&refresh=true";
} else {
if (states[variables.entity].attributes.thumb != ''){
return "https://tautulli-URL/api/v2?apikey=xxx&cmd=pms_image_proxy&img=" + states[variables.entity].attributes.thumb + "&width=300&height=450&fallback=poster&refresh=true"
} else {
return states['sensor.' + states[variables.entity].attributes.user + '_session_thumbnail'].state
card_mod:
style: |
ha-card {
box-shadow: 0;
border-radius: 0;
margin: 5px 0 0 -5px;
ha-card img {
min-height: 100px;
min-width: 100px;
bar:
card:
type: custom:bar-card
entities:
- entity: this.entity_id
attribute: progress_percent
unit_of_measurement: '%'
positions:
icon: 'off'
indicator: 'off'
height: 19px
color: '#e49f29'
return states[variables.entity].state
card_mod:
style: |-
ha-card {
--ha-card-background: none;
border: none;
box-shadow: none;
ha-card #states {
padding: 0;
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 5px;
left: 0;
bar-card-name {
margin-left: 3%;
text-shadow: 1px 1px 1px #0003;
bar-card-value {
margin-right: 3%;
user: |
return "<b>" + states[variables.entity].attributes.user + "</b>"
title: |
if (states[variables.entity].state == 'playing') {
return "<ha-icon icon='mdi:play' style='width: 15px; height: 15px; position: relative; top: -2px;'></ha-icon> " + states[variables.entity].attributes.full_title;
} else {
if (states[variables.entity].state == 'paused') {
return "<ha-icon icon='mdi:pause' style='width: 15px; height: 15px; position: relative; top: -2px;'></ha-icon> " + states[variables.entity].attributes.full_title;
} else {
return states[variables.entity].attributes.full_title;
stream_label: <b>Stream</b>
stream: >
let transcode_hw = states[variables.entity].attributes.transcode_hw;
let transcode_hw_str = (transcode_hw == 1) ? " (HW)" : "";
return states[variables.entity].attributes.video_resolution + " > "
states[variables.entity].attributes.transcode_decision +
transcode_hw_str + " > " +
states[variables.entity].attributes.stream_video_resolution;
product_label: <b>Product</b>
product: |
return states[variables.entity].attributes.product
player_label: <b>Player</b>
player: |
return states[variables.entity].attributes.player
location_label: <b>Location</b>
return states[variables.entity].attributes.location + ": " + states[variables.entity].attributes.ip_address
media_detail: |
if(states[variables.entity].attributes.media_type == 'movie') {
return "<ha-icon icon='mdi:filmstrip' style='width: 15px; height: 15px; position: relative; top: -2px;'></ha-icon> (" + states[variables.entity].attributes.year + ")";
} else {
return "<ha-icon icon='mdi:television-classic' style='width: 15px; height: 15px; position: relative; top: -2px;'></ha-icon> S" + states[variables.entity].attributes.parent_media_index + " • E" + states[variables.entity].attributes.media_index;
bandwidth_label: <b>Bandwidth</b>
bandwidth: |
var bytes = states[variables.entity].attributes.bandwidth * 1000;
var sizes = ['Bytes', 'Kbps', 'Mbps', 'Gbps', 'Tbps'];
if (bytes == 0) return 'n/a';
var i = parseInt(Math.floor(Math.log(bytes) / Math.log(1000)));
if (i == 0) return bytes + ' ' + sizes[i];
return (bytes / Math.pow(1000, i)).toFixed(1) + ' ' + sizes[i];
card_mod:
style: |
ha-card {
box-shadow: 0;
padding: 0;
margin: 0;
border: 0;
ha-card #container {
margin: 5px 0 0 0;
#name {
display:none;
styles:
card:
- height: 100x
- padding: 0
custom_fields:
bar:
- text-transform: capitalize
- font-size: 13px
user:
- text-align: end
- font-size: 15px
title:
- text-align: start
- font-size: 13px
stream:
- text-align: start
- font-size: 13px
product:
- text-align: start
- font-size: 13px
player:
- text-align: start
- font-size: 13px
- text-transform: uppercase
- text-align: start
- font-size: 13px
media_detail:
- text-align: start
- font-size: 13px
bandwidth:
- text-align: start
- font-size: 13px
product_label:
- text-align: end
- font-size: 10px
player_label:
- text-align: end
- font-size: 10px
stream_label:
- text-align: end
- font-size: 10px
location_label:
- text-align: end
- font-size: 10px
bandwidth_label:
- text-align: end
- font-size: 10px
grid:
- grid-template-areas: |
"picture product_label product"
"picture player_label player"
"picture stream_label stream"
"picture location_label location"
"picture bandwidth_label bandwidth"
"picture bar bar"
"picture title title"
"picture media_detail user"
- grid-template-columns: 1fr 60px 3fr
- grid-gap: 5px 10px
card:
type: vertical-stack
card_param: cards
Looks like this now
Mit freundlichen Grüßen
Chris
