Tcl home integration
ha-tcl-home-unofficial-integration
now, supported device types
  • Split AC
  • Split AC Fresh air
  • Portable AC
  • Window AC
  • Dehumidifier (DEM)
Thank you very much, @nemesa, for this integration!
It works great!
Amazing. This works perfectly and so easy to install. I’m not an expert, but this is great. Exactly what I needed. I wanted to control the TCL split airo via Homeassistant so I can create some logic on/off schedules (like if energy price = above a certain value, shut down airco. Or start cooling if temperature is above x).
Now it can be done! Very big thanks!!!
Works like a charm.
I was unable to set up my newly bought TCL ACs with the Tuya or Smart Life apps, like some people were able to do on the net. The unofficial integration posted above worked perfectly.
  1. TCL air conditioning TAC-09CHSD/XA41I has been integrated into Home Assistant and connected 32 entities, thank you, great job
Has anyone tested this integration for local control of a TCL air conditioner?
https://github.com/Tinnci/ha-tcl-udp-ac/tree/main
