TCP Connected Lighting (Greenwave Reality) MQTT Integration
I’m aware that there is a built-in component for these lights, but I’ve never had it work reliably and it crashed my TCP hub every couple of days.
As I had been using bren1818’s TCPLightingWebInterface without issue I decided to expand it to work with MQTT. I have been using this expanded MQTT function without issue for over a year. Recently there was some interest in the project so I have made some changes to allow for greater levels of customization as well as building a component for HASS’ MQTT discovery function.
Full disclosure I am not a programmer and the documentation is currently a little light, but should include all that is needed to get it up and running. Constructive comments or pull requests welcome.
The project is available at https://github.com/sktaylortrash/TCPLightingWebInterface-MQTT
The project has been updated to include an availability topic to determine if a light has gone offline. i.e. someone turned off the switch
Additionally it has been updated with better documentation
Thanks for sharing !
