Obviously the good news is I have some control but there seems to be limitations. I am trying to create automations. When my TV goes into standby i want to turn off the Audio system. But it seems the HA GUI doesn’t allow me to select the switches as a device to control.
So I guess I need to look at setting up a device and not switches .
Thanks for the help, initially I tried to use ‘call service’ but couldn’t find the entity. on the GUI when configuring automation I found the entity under the service ‘switch.turn_on’ selection. This is a typical thing of looking in the wrong place.
I’m still playing and I’m thinking there must be a better solution than using I/O switches. ideally, I need the ability to control inputs and volumes
Let me explain what I am achieving. I have an LG TV and a Meridian Audio amplifier. The amplifier needs to turn on with the TV and to be set to a specific input, in this case it’s called ‘TV’. When I turn off the TV then the amplifier needs to turn off (automatically).
The Meridian Amplifier is not a supported device in Home Assistance. I am able to control the LG TV via the WebOS integration found in Home Assistant.
With my work so far on this project I have Automations that turn on the Meridian Amplifier when the TV is on and to the correct inputs. I have similar automation when I turn the TV off. As an additional bonus there are IR code sets on the LG Store for their ‘magic’ remote to support Meridian volume and mute commands. This means I have a functioning system that only uses one remote control. BUT. I would like to also control the Meridian Amplifiers Volume directly from Home Assistant (via TCP). I may also use additional inputs on the amplifier, which is effectively a button push (not toggle or discreet on/off) thus not a switch. Hence my question on inputs.
I hope that helps explain my situation a little better.
