TCP request stopped working after update 2022.12 (custom_component)
After update 2022.12.xx the TCP request stopped working.
No compilation error but the connection fails.
If I set the framework to version 2.0.0 everything works again, but I’d like to fix the code to keep everything running without a workaround.
Any idea?
yaml:
substitutions:
  #Configurações do dispositivo:
  friendly_name: Teste
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable Home Assistant API
api:
  encryption:
    key: !secret teste_key
packages:
  device_base: !include .device_basic_remote_esp32.yaml
wifi:
  use_address: !secret teste_ddns
esphome:
  includes:
    - ./teste/teste.h
custom_component:
- lambda: |-
    auto command = new CommandComponent();
    return {command};
teste.h
#include "esphome.h"
#include "WiFi.h"
unsigned long previousMillis = 0;
unsigned long currentMillis = millis();
const long interval = 10000;
int connection_failed = 0;
int max_connection_failed = 3;//
//// Check loop time
unsigned long StartTime = millis();
unsigned long CurrentTime = millis();
unsigned long ElapsedTime = CurrentTime - StartTime;
const uint16_t port = 9054;
const char * host = "192.168.xx.xx";
int timeout = 500; //  timeout in milliseconds
String Status = {"\x00\x01\x02\x03\x04"};
String line;
String Model = " ";
class CommandComponent  : public Component  {
  public:
    void setup() override {
    void loop() override {
        if (millis() - previousMillis >= interval) {
          previousMillis = millis();
          status_update();
          if ((ElapsedTime >= 30) && (ElapsedTime <= 1000)) {
            Serial.print("ElapsedTime: ");
            Serial.println(ElapsedTime);
      line = "";
    void status_update() {
        WiFiClient client;
        if (!client.connect(host, port, timeout)) {
          Serial.println("Connection to host failed");
          ESP_LOGD("ERROR", "Connection to host failed");
          connection_failed++;
          if (connection_failed > max_connection_failed) {
            ESP_LOGD("ERROR", "Connection to host failed max exceeded");
          return;
        client.print(Status);
        line = client.readStringUntil(timeout);
        delay(5);
        ESP_LOGD("Teste", "Teste %s", line);
        client.stop();
workaround:
esp32:
  board: esp32dev
  framework:
    type: arduino
    version: 2.0.0
