Teegram_bot config problem driving me nuts
I’ve tried pretty much every spacing option presented in the docs and this forum that I can find of but keep getting this error when I do a CHECK CONFIGURATION. I’ve dumbed it down completely.
Invalid config for [telegram_bot]: expected int @ data['telegram_bot'][0]['allowed_chat_ids'][0]. Got None. (See /config/configuration.yaml, line 52).
Here’s my exact entries in configuration.yaml
notify:
  - platform: telegram
    chat_id: xxxxx
telegram_bot:
  platform: webhooks
  api_key: xxxxx
  allowed_chat_ids:
    - xxxxx
Any ideas? I have the iOS app working with a BotFather created bot.
Jeff
It all looks good.
Make sure to put quotes around your api_key. If it happens to have any special characters, it could throw off YAML parsing, including having it report errors on unrelated sections.
Make sure the chat ids are numbers, but I’m pretty sure that part is true.
Otherwise, nothing obvious stands out…
That is my exact code copied from my configuration.yaml.
Once I get past the error, I’ll put things in secrets.yaml etc, but I’m just trying to get rid of the error at this point with zero luck. And I’m out of ideas to try next.perhaps something is truly broken ? I’m running supervisor 214.
Jeff
If you’re actually putting -xxxxx, it won’t work as it’s trying to convert it to a number.
Just put in - 12345 as a placeholder.
SOLVED. Numbers…
Thanks a bunch.
Now if I could only figure out why I’m getting this annoying but harmless error
Component error: history_graph - Integration ‘history_graph’ not found.
I dont know where that sits as I don’t have it in my list of integrations.
The history_graph integration was removed. It wont show up in the list of integrations…because it’s not there.
You have to have it defined somewhere in your configuration.yaml, or one of the included files. You could have added it years ago and never used it…but now it’s gone and giving you an error.
