Telegram notification sends repeated pictures
Hello all !
This morning while i was setting up a new automation I found a strange behaviour.
I was setting up an automation that , after a trigger, take some photos from camera service and sent them , with other snapshots via telegram notification.
What i said is that if i send via notification the url of the snapshots and then the files what arrives to my phone are only the url snapshots repeated many time as the total number of pictures expect.
I discovered then that i can solve the problem inverting the send order …
The following is the automation that doesn’t work properly :
- alias: Antifurto Scala
    - platform: state
      entity_id: binary_sensor.motion_sensor_158d00024e693c
      to: 'on'
     condition:
   xxx
   xxx
   xxx
    - service: notify.ios_iphonexdimarco
      xxx
      xxx
      xxx
    - service: persistent_notification.create
     xxx
     xxx
     xxx
    - service: camera.snapshot
        entity_id: camera.camera_5
        filename: '/config/www/tmp/cortile5_foto.jpg'
        entity_id: camera.da_decidere
        filename: '/config/www/tmp/terrazzo_foto.jpg'
    - service: notify.telegram
        title: "Attenzione: Movimento rilevato in scala"
        message: 'Attenzione, {{ now().strftime("%H:%M %Y-%m-%d") }}: presenza rilevata dal sensore scala'
          photo:
            - url: http://admin:[email protected]/image/jpeg.cgi
            - file: /config/www/tmp/terrazzo_foto.jpg
            - file: /config/www/tmp/cortile5_foto.jpg
the above code sends 4 pictures the 1st one is ok, the 2nd is ok but the 3rd and the 4th are same as the 2nd.
The camera.snapshot service saves the correct picture.
Instead, as i told , if i change the order of the picture sent it works correctly
    - platform: state
      to: 'on'
     condition:
   xxx
   xxx
   xxx
      xxx
      xxx
      xxx
     xxx
     xxx
     xxx
          photo:
the cons above is working correctly.
Is someone having meet this strange behaviour ? ( or maybe I’m doing something wrong ?)
