Telia F2 Router (Kaon AR6445G) – custom integration, reverse-engineered local API
(Egen Home Assistant-integrasjon for Telia F2-ruteren, satt sammen ved å reverse-engineere ruterens eget lokale admin-grensesnitt.)
The Telia F2 (a Kaon AR6445G, sold by Telia across Norway/Sweden/the Baltics) has no official Home Assistant integration and no public API documentation, so I reverse-engineered its own local admin web UI to build one.
It talks directly to the router over your LAN (ws://<router-ip>/ws) — nothing goes through Telia’s or Kaon’s servers.
Features
  • Sensors: CPU load, free memory, uptime, WAN IP, connected-device count, ethernet port status
  • Binary sensors: WAN connectivity, mesh extender connectivity (with backhaul signal as attributes)
  • One sensor with a full attribute list of every connected client (wired + wireless) instead of one entity per client
  • Button to restart the router
Not implemented yet: toggling Wi-Fi bands on/off (the router’s own UI makes this awkward). PRs welcome.
Install via HACS
  1. HACS → the three-dot menu → Custom repositories
  2. Add https://github.com/PolsaFH/ha-telia-f2, category Integration
  3. Install, restart Home Assistant, add the integration from Settings → Devices & Services
Repo: GitHub - PolsaFH/ha-telia-f2: Home Assistant integration for the Telia F2 router (Kaon AR6445G) via a reverse-engineered local JSON-RPC/WebSocket API · GitHub
MIT licensed. Issues and PRs welcome.
