After upgrade to 0.85 I had to add «TelldusLive» to configuration.yaml. I used the integration tab in GUI before this.
After that Telldus is still detected as a new integration. So i thought I would link it again, but when trying this the link you are asked to click doesnt work.
Tried to remove everything from configuration.yaml and remove telldus.conf but this doesnt do anything.
Ok, after this I have a problem.
All my telldus live sensors now have “_2” after them in the entity name.
Before: sensor.hall_temperature
Now: sensor.hall_temperature_2
When I try to change the entity name I get an error that the entity is already present (old name).
How can I fix this?
Edit: I ended up removing my entire “.storage” folder and then readded all my intergrations.
I guess there is a better way so if anybody knows it could be good to know for future errors.
