I have a question, I installed Home Assistant today.
I have Tellstick Net with two Roller Shutter, they come up as a switch with the rest of telldus live switches I have. But they don´t take the command on and off as the command for tellstick motorized is up, down or stop, how can we get the telldus component to see if a device is motorized or not so it knows what command to send?
Excuse if I´m not explained it too well for you, as I´m half a sleep writing this.
Sounds like you would need a Tellstick roller shutter platform for your devices. Unfortunately this one is missing at the moment. I suggest that you create a feature request.
@hurricaneb, I would very much appreciate if you could test the support for your ruller shutter, once https://github.com/home-assistant/home-assistant/pull/4645 is merged. I think it should work now, but since I don’t have access to any motorized device myself, I have only been able to test the implementation using a configured “dummy” device.
