I’m in need of getting my tellstick duo to work with hass.io, is there any way, and if so how, to use this one?
Pretty new to docker and I used the installation command to create the Home-assistant setup (creating hass and supervisor container automatically) I’ve also enable samba, mqtt etc from the supervisor inside hass.io, could you do the same with this image?
