Tellstick Add-on not working in Debian Buster?
Fresh install of HA Supervised on Debian 10 Buster. Not able to get Tellstick add-on working. Worked fine in my previous Ubuntu 18.04 install.
Had to re-compile telldus-core from source and install manually to get it working in Debian. Works fine from command line with tdtool. But Home Assistant is not able to find Tellstick. Any ideas?
Home Assistant log:
2020-10-25 12:46:02 ERROR (SyncWorker_23) [homeassistant.components.tellstick] TellStick not found (-1)
2020-10-25 12:46:04 ERROR (SyncWorker_12) [homeassistant.components.tellstick] TellStick not found (-1)
2020-10-25 12:50:10 ERROR (SyncWorker_36) [homeassistant.components.tellstick] TellStick not found (-1)
2020-10-25 12:50:14 ERROR (SyncWorker_46) [homeassistant.components.tellstick] TellStick not found (-1)
2020-10-25 12:50:15 ERROR (SyncWorker_21) [homeassistant.components.tellstick] TellStick not found (-1)
2020-10-25 12:50:17 ERROR (SyncWorker_1) [homeassistant.components.tellstick] TellStick not found (-1)
Configuration.yaml:
tellstick:
  host: core-tellstick
  port: [50800, 50801]
  signal_repetitions: 3
switch:
  platform: tellstick
Tellstick config:
devices:
  - id: 1
    protocol: arctech
    model: codeswitch
    house: A
    unit: '1'
Tellstick add-on log:
[12:49:43] INFO: Initialize the tellstick configuration...
[12:49:44] INFO: Exposing sockets and loading service...
telldusd daemon starting up
[12:49:44] INFO: Starting event listener...
Connecting to TellStick (1781/C31) with serial A6X2Sxxx
Disconnected TellStick (1781/C31) with serial A6X2Sxxx
System info:
arch	x86_64
chassis	laptop
dev	false
docker	true
docker_version	19.03.13
hassio	true
host_os	Debian GNU/Linux 10 (buster)
installation_type	Home Assistant Supervised
os_name	Linux
os_version	4.19.0-12-amd64
python_version	3.8.5
supervisor	249
timezone	Europe/Stockholm
version	0.116.4
virtualenv	false
