I am trying to control my Optoma projector. I can connect directly using Telnet commands so I know the projector responds correctly but when I try and add the following to the configuration.yaml folder I get an error and Home assistant will not restart?
Here is the file:
Optoma Projector 192.168.2.12
- platform: telnet
switches:
projector:
resource: 192.168.2.12
port: 23
command_on: “~0000 1”
command_off: “~0000 0”
command_state: “~00124 1”
value_template: ‘{{ value == “OK1” }}’
timeout: 0.9
Here is the error:
Logger: homeassistant.components.homeassistant
Source: components/homeassistant/init.py:310
Integration: Home Assistant Core Integration (documentation, issues)
First occurred: 2:12:57 PM (1 occurrences)
Last logged: 2:12:57 PM
The system cannot reload because the configuration is not valid: Platform error sensor.telnet - No module named ‘homeassistant.components.telnet.sensor’
Thanks in advance:)
