hello , I am new to HA. I have an elesion temperature sensor. how can I integrate it ?
the ts is wifi enable and give temp and humidty.
I have an android application elesion where I can see my sensor attribute.
I have try a generic ts with yaml config but don’t see the device
the ip addr of the sensor is out of my internal network, so it is strange to me.
hello, I will make the question and the answer !!!
my ts is from pearl and is supprted with ELESION and Tuya
I have discovered the ts in tuya.
easily found how to integrade tuya in ha and I have my ts in HA
Same procedure for a plug
however the ts is not discovered in google home (the plug is). a bit disapointed I cannot get the ts in google.
perhaps I will try to inegrate ha and google assistant.
Hi - can you explain how you got your Pearl / Elesion device added via Tuya? I have another device working in HA using the Tuya integration, bet I can’t get this Pearl thermostatic plug to work.
I’ve installed the Elesion app and registered the device OK, but that app is not recognised by the Tuya IoT portal. So I tried the Tuya/Smart Life app instead, and that refuses to recognise the device. Any help appreciated!
Install tuya app in your smartphone. configure your device like in elesion.
install local tuya with HACS and follow the documentation for configuring Tuya.
Out of my memory , you have to go in the developement section, create adeveloppement project, define some autorization, scan a qr-code and you get the device in the project.
in HA add a bridge with project and user credential.
good luck
