I have a BHT-002-GALW (TS0601 _TZE200_aoclfnxz) and it the temperature is about 3 C° to hot.
I use zha with the current ha version.
In the cluster manager in Cluster MoesBHTThermostat I set local_temperature_calibration with value -3. No error occurs.
But the temperature doesn’t change.
Has anyone an idea how to correct the temperature?
If using the ZHA integration and all sensors of the exact same brand and model show the same wrong values then suggest report as a bug to the ZHA Device Handlers repository on GitHub → https://github.com/zigpy/zha-device-handlers/issues
Yes however note that you need a separate Zigbee USB adapter and the Zigbee networks that they control will not talk to each other so the interactions between them have to be at the application layer/level, (so there is no communication between them what so ever at the Zigbee layer/level).
