Temp. switch between Z-Wave JS UI and Z-Wave.me for testing purposes / controller fw upgrade
Hello, running HA OS on RPi4 with latest Z-Wave JS UI add-on and would like to occasionally start Z-Wave.ME add-on (used in the past, now disabled) to check if there is any online fw update/upgrade for my RaZberry 7 board.
Can I do this without messing my existing devices/entities from Z-Wave JS UI?
Do I need to temporarily disable Z-Wave JS integration while running the Z-Wave.me add-on, in order to preserve existing devices/entities?
(definitely I do not need to start Z-Wave.me integration as that might mess my devices/entities)
Thanks for the help and suggestions…
Miodrag
Feels like a bit of a messy approach, IMHO, especially for something that isn’t frequent.
You’d need to stop the zwavejs container as it will have control of the z-wave interface hardware. Not sure about stopping the zwavejs integration - guess it might help to avoid the risk of it deciding the nodes have disappeared.
Personally, I’d have z-wave.me installed natively on RasPiOS on a different SD card and just shut down HA completely, swap cards, use z-wave.me to check firmware, then go back HA. You only need to run z-wave.me when there is an update, and those should be posted on their website. If their site/repo is consistently-structured, there might even be a way to create a http-based sensor that checks for updates…!
Good suggestion, thanks! - only issue is some amount of HA downtime…
This should work fine without issue.
  1. Stop the ZUI add-on. The Z-Wave integration will lose connection to zwave-js-server and all entities will go unavailable.
  2. Start the Z-Wave.me add-on and do all the things you need to do. Stop it when done. Make sure the add-on is not configured to auto-start.
  3. Start the ZUI add-on. The Z-Wave integration will re-connect automatically and all entities will be available again.
Thanks @freshcoast - do I need to stop ZWave JS integration as well in order to stop Z-Wave.me add-on messing with my device/entities? Or when ZUI add-on is stopped it will just make them unavailable without any other consequences?
No, you don’t need to disable the integration, you can if you prefer.
Thanks, I’ll try now and post results…
Works like a charm, no devices/identites lost, stopped ZUI, started ZW.me, checked fw release for RaZberry 7 with Z-Wave.me add-on, stopped ZW.me add-on, re-activated ZUI add-on…
