This is quite a big update
. I am slowly going through my blueprint so they all look and feel the same
Please read this before upgrading. If you use “Fan Speed - Switch Off Option” in you automations, once you upgrade you will need to select “Enable the fan speed - switch off option” as shown below and click save.
New Features
Added “Fan” domain to fan switch.
Added enable / disable option to the “Fan Speed – Switch OFF Option”.
Added Fan domain to “Fan Speed – Switch OFF Option”.
Upgraded by-pass to have 3 options. You can now choose what you would like the fan to do when you turn the by-pass ON.
- Turn fan ON.
- Turn fan OFF.
- Keep the current fan state.
Added the ability to use a “By-pass Auto OFF Option”. This is used when you turn the by-pass ON and you would like the by-pass to automatically turn OFF in a set time delay. It can also be used as a timer to turn the fan ON and then OFF if you have chosen to use “Enable the By-pass - Turn fan ON”.
Added end of time trigger. The fan will turn OFF when end time crosses over and your “Rising Value” is over it’s setting.
Added some safe guards for HA restart.
Cleaned up some code.
Bugs Fixes
- Start of time trigger.
- Some other bugs.
If you like this blueprint? Consider hitting the
button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Enjoy
Blacky
