johnvpr
(johnvpr)
May 13, 2022, 4:29pm
1
Once I add the temperature to the notification the Automation breaks
alias: Fridge open for X minutes
description: ''
- type: temperature
platform: device
device_id: c6f39af9eb083ffaf219296a47b0f69e
entity_id: sensor.frezer_temperature_2 #EDITED
domain: sensor
above: -5
for:
hours: 0
minutes: 1
seconds: 3
milliseconds: 0
condition: []
- service: telegram_bot.send_message
message: Temp {{ state_attr('sensor.frezer_temperature_2','temperature') }}
mode: single
this is my sensor
johnvpr:
state_attr
when you add “temperature” or " state_attr “, or does your “service: telegram” work with a Hello World” ?
Does you temperature_device have an attribute called “temperature” ?
EDIT: I assume you have noticed the trailing _2 on your entity, and that 1 (same friendly name )is unavailable in your card
i.e IF your read your attached code, you’ll notice you use 2 different entities
and
state_attr(‘sensor.frezer_temperature_2’
and you try to show state_attr(attribute) from your temp_sensor, and not i.e
{{ states('sensor.frezer_temperature_2') }} or what ever sensor you decide you want the state from
johnvpr
(johnvpr)
May 13, 2022, 6:37pm
4
Yes, Telegram works with Hello World.
the sensor.frezer_temperature_2 is the one I want the temperature from, it shows -20c but i’m not able to pull it with:
message: Fridge open: Temp {{ state_attr('sensor.frezer_temperature','temperature') }}`
if I use:
message: Fridge open: Temp {{ state('sensor.frezer_temperature_2') }}
then I will get NONE
Fridge open:Temp None
and if I use:
message: Fridge open: Temp {{ 'sensor.frezer_temperature_2' }}
I will gent also NONE
not sure how to see if the device has an attribute temperature:
which one is showing “unavailable” in your card ? … you have to know whether it is
sensor.frezer_temperature_2 or sensor.frezer_temperature that works and then ONLY use this in your automation
NOTE: You use 2 different sensors in your automation( im very certain that 1 of these is NOT available, AS your card says", … you take temperature from 1 sensor, then use another sensor in you “message” ? … it’s like saying “check temp i frezer and send me message with temperature from fridge”
- type: temperature
platform: device
domain: sensor
above: -5
for:
NOTE ABOVE:: entity_id: sensor.frezer_temperature
NOTE ABOVE: sensor.frezer_temperature_2
Do you have 2 sensors in your Frezer, as your card shows ?
johnvpr
(johnvpr)
May 13, 2022, 7:11pm
6
And this is my espHome device:
dallas:
- pin: GPIO0
- platform: dallas
address: 0xDA0516A4B4C8FF28
name: "Frezer Temperature"
johnvpr
(johnvpr)
May 13, 2022, 7:16pm
7
and not sure which are frezer_temperature_2 and frezer_temperature.
however the one what shows the temp on the card is frezer_temperature_2
then change your automation to
- type: temperature
platform: device
johnvpr
(johnvpr)
May 13, 2022, 7:21pm
9
unfortunately it will not work also with frezer_temperature_2 in the trigger.
I’m having the problem that I can send Hello World but non of these are working:
pedolsky
(Pedolsky)
May 13, 2022, 7:29pm
10
Try
message: "Fridge open: Temp {{ state_attr('sensor.frezer_temperature','temperature') }}"
or
# states, not state
message: "Fridge open: Temp {{ states('sensor.frezer_temperature_2') }}"
johnvpr
(johnvpr)
May 13, 2022, 7:37pm
11
pedolsky:
states(
Finally got it to work!!!
I also changed the name of frezer_temperature_2 to frezer_temp
message: Frige Open Temp {{ states('sensor.frezer_temp') }}
Thank you so much!!!
pedolsky
(Pedolsky)
May 13, 2022, 7:40pm
12
You can always check your Jinja code via Developer Tools —> Template.
