Hello, I have a broadlink RM1 sensor that I am currently using as a temperature sensor too. I have it integrated into a climate component and I have detected that going from 24.8 to 24.9 degrees makes the reading wrong and it measures 249 degrees (without decimals). Is there any way to fix this? I don’t know if modifying any file can be done since I only have the config folder exposed and there I don’t see anything related to the sensor. Thank you very much to all.
Nobody knows anything about it? I have problems in automations due to this error and I do not know how to solve it
