Im trying to read the Temperature sensor TFA Dostmann 433mhz with Home assistant trough Rfxcomxl.
But Home assistant receives the pulse but it can’t translate the data:
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:620
Integration: Recorder
First occurred: 8:49:56 PM (2 occurrences)
Last logged: 8:49:56 PM* Event is not JSON serializable: <Event rfxtrx_event[L]: packet_type=3, sub_type=12, type_string=nec, id_string=Undecoded, data=05030c000700, values=Payload=bytearray(b’\x07\x00’)>: Type is not JSON serializable: bytearray
