Hi everyone!
I’m writing a program in Java to access/control Home Assistant using its REST API. Currently, I want to implement the whether entity. The documentation says, that temperature_unit
is a required field, but my API-response does not contain that property. Also, the value of the temperature
property changes when I switch between Celsius and Fahrenheit in Home Assistant settings with seemingly no indication in the backing weather entity.
Is this intended and I have to find out the actual unit some other way? If so, how?
Similarly for wind_speed
: the documentation only states that it is in “km/h or mi/h”, so how can the GUI figure out that it actually is the former? And last point: according to the documentation, wind_speed
in the forecast should be an int
, but it seems to be a float
as well…
Thank you in advance for all your comments!
