Template action response_variable is undefined
Hey experts,
I’ve been stuck working this issue now for a few hours and looking to see if anyone might have a quick fix. Working to create a template that pulls in weather data using weather.get_forecasts and uses response variables to get both daily and hourly data. When using the template I get UndefinedError: ‘hourly’ is undefined even though my format is the exact same as is in the Home Assistant documentation for weather. Any ideas are greatly appreciated!
- trigger:
    - platform: time_pattern
      minutes: "0" # Runs hourly at minute 0
    - platform: homeassistant
      event: start # Triggers when Home Assistant starts
    - service: weather.get_forecasts
        entity_id: weather.forecast_home
        type: hourly
      response_variable: hourly
        type: daily
      response_variable: daily
    - service: persistent_notification.create
        title: "Forecast Output"
        message: "{{ hourly }}"
    - name: Weather Forecast
      unique_id: weather_forecast
      state: "{{ now().isoformat() }}"
      attributes:
        now_condition: "{{ hourly['weather.forecast_home'].forecast[0].condition }}"
        now_icon: >
          {% set weather = hourly['weather.forecast_home'].forecast[0].temperature %}
          {% if is_state('sun.sun', 'above_horizon') %}
          {{ '/local/weather' + weather|string + '.svg' }}
          {% else %}
          {{ '/local/weather' + weather|string + '_night.svg' }}
          {% endif %}
        now_temp: "{{ hourly['weather.forecast_home'].forecast[0].temperature }}"
        now_wind_speed: "{{ hourly['weather.forecast_home'].forecast[0].wind_speed }}"
        now_wind_bearing: "{{ hourly['weather.forecast_home'].forecast[0].wind_bearing }}"
        now_precipitation: "{{ hourly['weather.forecast_home'].forecast[0].precipitation }}"
        #now_precipitation_probability: "{{ hourly['weather.forecast_home'].forecast[0].precipitation_probability }}"
        now_humidity: "{{ hourly['weather.forecast_home'].forecast[0].humidity }}"
        now_feels_like: >
          {% set temperature = hourly['weather.forecast_home'].forecast[0].temperature %}
          {% set humidity = hourly['weather.forecast_home'].forecast[0].humidity %}
          {% set windspeedmps = hourly['weather.forecast_home'].forecast[0].wind_speed / 3.6 %}
          {% set e = 2.71828 %}
          {% set wvp = (humidity/100) * 6.105 * e**((17.27*temperature) / (237.7 + temperature)) %}
          {{(temperature + 0.33 * wvp - 0.70 * windspeedmps - 4.00)|round(2)}}
        now_wind_direction: >
          {% set direction = ['N','NNE','NE','ENE','E','ESE','SE','SSE','S','SSW','SW','WSW','W','WNW','NW','NNW','N'] %}
          {% set degree = (hourly['weather.forecast_home'].forecast[0].wind_bearing | float) %}
          {{ direction[((degree + 11.25) / 22.5) | int] }}
        now_wind_desc: >
          {% from 'weather_wind.jinja' import get_wind_description %}
          {{ get_wind_description(hourly['weather.forecast_home'].forecast[0].wind_speed | float) }}
        today_condition: "{{ daily['weather.forecast_home'].forecast[0].condition }}"
        today_icon: >
          {% set weather = daily['weather.forecast_home'].forecast[0].temperature %}
        today_temp: "{{ daily['weather.forecast_home'].forecast[0].temperature }}"
        today_wind_speed: "{{ daily['weather.forecast_home'].forecast[0].wind_speed }}"
        today_wind_bearing: "{{ daily['weather.forecast_home'].forecast[0].wind_bearing }}"
        #today_precipitation_probability: "{{ daily['weather.forecast_home'].forecast[0].precipitation_probability }}"
        today_humidity: "{{ daily['weather.forecast_home'].forecast[0].humidity }}"
        today_feels_like: >
          {% set temperature = daily['weather.forecast_home'].forecast[0].temperature %}
          {% set humidity = daily['weather.forecast_home'].forecast[0].humidity %}
          {% set windspeedmps = daily['weather.forecast_home'].forecast[0].wind_speed / 3.6 %}
        today_wind_direction: >
          {% set degree = (daily['weather.forecast_home'].forecast[0].wind_bearing | float) %}
        today_wind_desc: >
          {{ get_wind_description(daily['weather.forecast_home'].forecast[0].wind_speed | float) }}
        forc1_datetime: "{{ daily['weather.forecast_home'].forecast[1].datetime}}"
        forc1_condition: "{{ daily['weather.forecast_home'].forecast[1].condition }}"
        forc1_icon: >
          {% set weather = daily['weather.forecast_home'].forecast[1].temperature %}
        forc1_temp: "{{ daily['weather.forecast_home'].forecast[1].temperature }}"
        forc1_precipitation: "{{ daily['weather.forecast_home'].forecast[1].precipitation }}"
        forc2_datetime: "{{ daily['weather.forecast_home'].forecast[2].datetime}}"
        forc2_condition: "{{ daily['weather.forecast_home'].forecast[2].condition }}"
        forc2_icon: >
          {% set weather = daily['weather.forecast_home'].forecast[2].temperature %}
        forc2_temp: "{{ daily['weather.forecast_home'].forecast[2].temperature }}"
        forc2_precipitation: "{{ daily['weather.forecast_home'].forecast[2].precipitation }}"
        forc3_datetime: "{{ daily['weather.forecast_home'].forecast[3].datetime}}"
        forc3_condition: "{{ daily['weather.forecast_home'].forecast[3].condition }}"
        forc3_icon: >
          {% set weather = daily['weather.forecast_home'].forecast[3].temperature %}
        forc3_temp: "{{ daily['weather.forecast_home'].forecast[3].temperature }}"
        forc3_precipitation: "{{ daily['weather.forecast_home'].forecast[3].precipitation }}"
        forc4_datetime: "{{ daily['weather.forecast_home'].forecast[4].datetime}}"
        forc4_condition: "{{ daily['weather.forecast_home'].forecast[4].condition }}"
        forc4_icon: >
          {% set weather = daily['weather.forecast_home'].forecast[4].temperature %}
        forc4_temp: "{{ daily['weather.forecast_home'].forecast[4].temperature }}"
        forc4_precipitation: "{{ daily['weather.forecast_home'].forecast[4].precipitation }}"
        forc5_datetime: "{{ daily['weather.forecast_home'].forecast[5].datetime}}"
        forc5_condition: "{{ daily['weather.forecast_home'].forecast[5].condition }}"
        forc5_icon: >
          {% set weather = daily['weather.forecast_home'].forecast[5].temperature %}
        forc5_temp: "{{ daily['weather.forecast_home'].forecast[5].temperature }}"
        forc5_precipitation: "{{ daily['weather.forecast_home'].forecast[5].precipitation }}"
Thanks again!
Where are you “using” this template?
Template sensors that use advanced functions like triggers need to be added to your configuration files.
If you are trying to test your templates using the Template Editor, you need to first use the Actions tool to retrieve the data (use the “Copy to Clipboard (Template)” button at the bottom of the response field.
Hi. I have the exact same issue. Yes, this is in the configuration.yaml file. Still says “variable is undefined”. I have read through half a dozen posts here about the same issue, no joy.
This is my config:
template:
  - trigger:
      - trigger: time_pattern
        hours: /1
        event: start
      - platform: event
        event_type: event_template_reloaded
      - action: weather.get_forecasts
          type: daily
        response_variable: response
  - sensor:
      - name: "Weather Forecast Text"
        unique_id: "weather_forecast_text"
        state: "Condition: {{response['weather.forecast_home'].forecast[0].condition}}"
With my config, I get “variable ‘response’ is undefined”.
Note that I am using met.no so their forecast response looks a bit different:
weather.forecast_home:
  forecast:
    - condition: cloudy
      datetime: "2025-08-04T10:00:00+00:00"
      wind_bearing: 253.1
      uv_index: 6
      temperature: 21.7
      templow: 16.5
      wind_speed: 21.6
      precipitation: 0.6
      humidity: 60
    - condition: sunny
      datetime: "2025-08-05T10:00:00+00:00"
      wind_bearing: 255.5
      uv_index: 7.3
      temperature: 27.2
      templow: 15.3
      wind_speed: 16.9
      precipitation: 1.3
      humidity: 62
    - condition: rainy
      datetime: "2025-08-06T10:00:00+00:00"
      wind_bearing: 290.2
      uv_index: 6.5
      temperature: 24
      templow: 15.9
      wind_speed: 19.4
      precipitation: 3.4
      humidity: 64
    - condition: partlycloudy
      datetime: "2025-08-07T10:00:00+00:00"
      wind_bearing: 100.3
      uv_index: 0
      temperature: 27.7
      templow: 14
      wind_speed: 13.7
      precipitation: 0
      humidity: 48
    - condition: sunny
      datetime: "2025-08-08T10:00:00+00:00"
      wind_bearing: 71
      temperature: 30.3
      templow: 18.1
      wind_speed: 7.2
      precipitation: 0
      humidity: 56
      datetime: "2025-08-09T10:00:00+00:00"
      wind_bearing: 51.4
      temperature: 32.1
      templow: 21.4
      wind_speed: 7.6
      precipitation: 0
      humidity: 57
Oh and just to clarify, running this action in the developer tools works and produces the above output:
  type: daily
because you have a - in front of sensor: which separates your - trigger: and action: from your sensor:.
Oh my god.
Yes that’s the problem. Thanks a lot, I was banging my head against the wall here!
For reference, here’s my working config using met.no:
template:
  - trigger:
        hours: /1
        event: start
      - platform: event
          type: daily
        unique_id: "weather_forecast_text_tts"
        state: >
           {% set forecast = response['weather.forecast_home'].forecast %} {% if forecast %}
             Today is {{ forecast[0].condition }} with {{ forecast[0].temperature | round(0) }} degrees celsius.
             and wind speeds of up to {{ forecast[0].wind_speed | round(0) }} kilometers per hour..
             Tomorrow will be {{ forecast[1].condition }} with {{ forecast[1].temperature | round(0) }} degrees celsius.
             and wind speeds of up to {{ forecast[1].wind_speed | round(0) }} kilometers per hour.
           {% else %}
             Forecast unavailable.
           {% endif %}
