Template and image url
I am a bit lost.
What is the difference between :slight_smile:
template:
    - trigger:
       - platform: state
         entity_id: weather.forecast_home_2
         to:
      image:
        - name: Wetterbild
          unique_id: 7bbd302d-3246-40ab-aad8-3760d1b75100
          url: >
            {% set condition = states('weather.forecast_home_2') %}
            {% if 'rain' in condition or 'sleet' in condition %}
              http://192.168.10.41:8123/local/images/rain.jpg
and :slight_smile:
template:
    - trigger:
       - platform: state
         to:
      image:
        - name: Wetterbild
          url: >
The first version works, the second doesn’t.
The first one download an image from a http server (in this case, home assistant, but could hold any url).
The second one tries to load an image from a local folder.
But… in automation, instead of using /local/, one should not use the linked folder but use the real folder location, which is: /config/www/
Try this:
OR… Collecting and Sharing Media Files
Hmm, that does not work either.
The reason why I am asking :slight_smile:
This is from the documentation :slight_smile:
template:
  - image:
      - name: "Room Status Picture"
        unique_id: room_status_picture
        url: >
          {% set state = states('light.living_room_lights') %}
          {% if state == 'on' %}
            /local/images/room_on.png
          {% else %}
            /local/images/room_off.png
          {% endif %}
I checked history and see the problem appearing again and again for several years; no real solution is given in these topics.
Probably I have to continue using the full url.
The option is asking for a URL, not a file path. Two different things.
The key is in the key name (pun!).
Ah…yes…sorry, @tom_l is right…
image map Required
List of images
url template Required
The URL on which the image is served.
Thank you !
