Kerimayhan
(UnbekannterAuthor)
March 4, 2024, 11:38am
1
knx:
- name: "Pixa Zone 1"
state_address: "11/3/200"
type: 1byte_unsigned
sync_state: 5
- name: "Pixa Zone 2"
state_address: "11/3/201"
sync_state: 5
- name: "Pixa Zone 3"
state_address: "11/3/202"
sync_state: 5
- name: "Pixa Zone 4"
state_address: "11/3/203"
sync_state: 5
- name: "Pixa Zone 5"
state_address: "11/3/204"
sync_state: 5
- name: "Pixa Zone 6"
state_address: "11/3/205"
sync_state: 5
template:
- sensor:
state: "{{ states('sensor.pixa_zone1') | float + states('sensor.pixa_zone2') | float + states('sensor.pixa_zone3') | float + states('sensor.pixa_zone4') | float + states('sensor.pixa_zone5') | float + states('sensor.pixa_zone6') | float}}"
I have a problem when adding multiple sensor data to a new entity. With the template code I provided above, I can create a new entity, but the data is not displayed (not available).
Additionally, I have these two additional codes. Can you tell me what the errors are here?
- sensor:
- name: "pixa_personenanzahl"
unique_id: "Pixa Personenanzahl"
state: >-
{% set persons = states('sensor.pixa_personenanzahl') | float(0) %}
{{ ((persons - 2) / 0,13) | round(0)}}
- sensor:
- name: "temperatur_ist"
unique_id: "Temperatur RTC"
state: >-
{% set temperature = states('sensor.temperatur_ist') | float(0) %}
{{ ((temperature - 18) / 0,08) | round(0)}} `
petro
(Petro)
March 4, 2024, 11:44am
2
Post the full configuration of the template
section without breaking it apart like you did.
The only thing I notice is that you have 2 sensors with the same name, which will result in an entity with an _2 at the end.
Outside that, your first pixa_personenanzahl entity can be made in the UI without templates as a sensor group helper with sum selected.
Kerimayhan
(UnbekannterAuthor)
March 4, 2024, 11:58am
3
knx:
- name: "CO2"
state_address: "11/3/10"
type: ppm
sync_state: 5
- name: "Humidity"
state_address: "11/3/11"
type: humidity
sync_state: 5
- name: "co2 in prozent"
state_address: "11/3/206"
type: percent
sync_state: 5
- name: "humidity in prozent"
state_address: "11/3/207"
type: percent
sync_state: 5
state_address: "11/3/0"
type: temperature
sync_state: 5
sync_state: 5
sync_state: 5
sync_state: 5
sync_state: 5
sync_state: 5
sync_state: 5
template:
- sensor:
state: >-
- sensor:
state: >-
I added the sum helper and it worked. so the only problem is the converting the value into %
petro
(Petro)
March 4, 2024, 12:05pm
4
Numbers in templates use decimal .
not ,
i.e. 5 and and half in templates is 5.5
not 5,5
Kerimayhan
(UnbekannterAuthor)
March 4, 2024, 12:13pm
5
template:
- sensor:
state: >-
{{ ((persons - 2) / 0.13) | round(0)}}
- sensor:
state: >-
{{ ((temperature - 18) / 0.08) | round(0)}}
if i watch the logs i get this error
Invalid config for 'template' at configuration.yaml, line 78: 'name' is an invalid option for 'template', check: name Invalid config for 'template' at configuration.yaml, line 80: 'state' is an invalid option for 'template', check: state
Invalid config for 'template' at configuration.yaml, line 85: 'name' is an invalid option for 'template', check: name Invalid config for 'template' at configuration.yaml, line 87: 'state' is an invalid option for 'template', check: state
petro
(Petro)
March 4, 2024, 12:27pm
6
you removed the proper indenting from your first post.
template:
- sensor:
state: >-
- sensor:
state: >-
Kerimayhan
(UnbekannterAuthor)
March 4, 2024, 12:53pm
7
got it. it works now thank you
Kerimayhan
(UnbekannterAuthor)
March 4, 2024, 1:09pm
8
If i show the result on my homepage it shows the exact number but it doesnt have the % sign at the end. Is it possible to add it? Because im using the Max combiner and if the result doesnt have the % sign the max combiner just ignores it
petro
(Petro)
March 4, 2024, 1:11pm
9
Add unit_of_measurement: %
and device_class: percent
to your template entities.
Kerimayhan
(UnbekannterAuthor)
March 4, 2024, 2:03pm
10
template:
name: “Personenanzahl in Prozent”
unique_id: “Pixa Personenanzahl”
state: >-
{% set persons = states(‘sensor.personenanzahl_total’) | float(0) %}
unit_of_measurement: “%”
device_class: “percent”
name: “Temperatur ist in Prozent”
unique_id: “Temperatur RTC”
state: >-
{% set temperature = states(‘sensor.temperatur_ist’) | float(0) %}
there are errors if i dont use the " " but now the template as a whole doesnt work
Kerimayhan
(UnbekannterAuthor)
March 4, 2024, 2:14pm
11
template:
state: >-
{{ ((persons - 2) / 0.13) | round(0)}}%
state: >-
{{ ((temperature - 18) / 0.08) | round(0)}}%
did it like this and it shows the % now
