I get an error for this template only once at startup:
type: entities
card_mod:
style: |
.card-header {
font-size: 18px;
margin: -10px 0px;
ha-card {
height: 172px !important;
#states > * {
margin: -1px 0px !important;
entities:
- entity: input_boolean.notification_erschutterung_16
card_mod:
style: |
:host {
{% if is_state(config.entity, 'on') %}
--secondary-text-color: red;
--paper-item-icon-color: red;
--card-mod-icon: mdi:vibrate;
{% else %}
--card-mod-icon: mdi:crop-portrait;
{% endif %}
type: custom:template-entity-row
state: "{% if is_state(config.entity, 'on') %}Erkannt{% else %}Keine{% endif %}"
secondary: >
{% set relativeTime = relative_time([
states.binary_sensor.vibrationssensor_16_erschutterung.last_updated,
states.binary_sensor.vibrationssensor_16_fallenlassen.last_updated,
states.binary_sensor.vibrationssensor_16_kippen.last_updated ] | max | default(0, true)) %}
{% if 'second' in relativeTime %}
{% set relativeTime = 'einigen Sekunden' %}
{% endif %} Vor {{ relativeTime | replace("years", "Jahre") |
replace("days", "Tagen") | replace("hours", "Stunden") |
replace("minutes", "Minuten") | replace("year", "Jahr") | replace("day",
"Tag") | replace("hour", "Stunde") | replace("minute", "Minute") }}
- entity: sensor.vibrationssensor_16_batterie
card_mod:
style:
hui-generic-entity-row $: |
.state {
color: {{ 'red' if states(config.entity) | int(default=0) <= 10 }};
- entity: number.vibrationssensor_16_empfindlichkeit
title: Gartenlaube
grid_options:
columns: 9
rows: auto
Error:
Logger: homeassistant.helpers.event
Source: helpers/template.py:645
First occurred: 11:01:11 (38 occurrences)
Last logged: 11:01:11
Error while processing template: Template<template=({% set relativeTime = relative_time([ states.binary_sensor.vibrationssensor_16_erschutterung.last_updated, states.binary_sensor.vibrationssensor_16_fallenlassen.last_updated, states.binary_sensor.vibrationssensor_16_kippen.last_updated ] | max | default(0, true)) %} {% if 'second' in relativeTime %} {% set relativeTime = 'einigen Sekunden' %} {% endif %} Vor {{ relativeTime | replace("years", "Jahre") | replace("days", "Tagen") | replace("hours", "Stunden") | replace("minutes", "Minuten") | replace("year", "Jahr") | replace("day", "Tag") | replace("hour", "Stunde") | replace("minute", "Minute") }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2236, in strptime
return datetime.strptime(string, fmt)
TypeError: strptime() argument 1 must be str, not LoggingUndefined
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 643, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2756, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1295, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.13/site-packages/jinja2/sandbox.py", line 401, in call
return __context.call(__obj, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2239, in strptime
raise_no_default("strptime", string)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1932, in raise_no_default
raise ValueError(
...<2 lines>...
ValueError: Template error: strptime got invalid input '' when rendering template '{% set relativeTime = relative_time(strptime(states.sensor.manfred_hohn_last_measurement_timestamp.state,'%Y-%m-%dT%H:%M:%S%z')) %} {% if 'second' in relativeTime %}
{% endif %} {{ states('sensor.manfred_hohn_measurement') }} mg/dl vor {{ relativeTime | replace("years", "Jahre") | replace("days", "Tagen") | replace("hours", "Stunden") | replace("minutes", "Minuten") | replace("year", "Jahr") | replace("day", "Tag") | replace("hour", "Stunde") | replace("minute", "Minute") }}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 760, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, **kwargs
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 645, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: strptime got invalid input '' when rendering template '{% set relativeTime = relative_time(strptime(states.sensor.manfred_hohn_last_measurement_timestamp.state,'%Y-%m-%dT%H:%M:%S%z')) %} {% if 'second' in relativeTime %}
Any idea what’s wrong?
