I need to decide which zone to irrigate depending on which zone was irrigated the longest time ago. I have 5 gpio switches and have created 5 corresponding input_datetime helpers to store the last irrigation date for each zone. I’m trying to calculate the best number with the following template as part of a script:
- service: input_number.set_value
entity_id: input_number.current_zone
value: >
{%- set ns = namespace(bestval='3000-01-01', bestnum='' -%}
{%- for i in states.input_datetime -%}
{%- if i.state|string < ns.bestval -%}
{%- set ns.bestval = i.state -%}
{%- set ns.bestnum = i.entity_id -%}
{%- endif -%}
{%- endfor -%}
{{ns.bestnum[-1:]|int|string}}
I did use the ‘namespace trick’ to modify the variable inside the jinja loop.
The template code works in the UI but fails to import as part of the script with the following error:
Invalid config for [script]: template value should be a string for dictionary value @ data['sequence'][2]['data']. Got None.
I couldn’t find any samples of loop calculations inside a script value, so not sure this is possible?
So {{ns.bestnum[-1:]}} should give me the last character of the entity_id - which is a number from 1 to 5. But now that you ask I realize the |int|string is actually pretty redundant thanks.
OK, the additional information helps to make sense of what the last line does but the redundant filters aren’t the cause of the error message.
The following template performs the same function as yours (report the last letter of the entity_id of the input_datetime containing the oldest date). Copy-paste it into the Template Editor to confirm it reports the correct value.
