I want to make a template from 2 string concat together.
Has example var1 = 40 and var2 = >80
I want the template to resolve that to var1 + var2 ==> 40>80 ==> false
Example in developer tools template
{% set var1 = "40" %}
{% set var2 = ">80" %}
{% set result = var1 + var2 %}
{{result}}
{% set var1 = 40 %}
{% set var2 = 80 %}
{% set result = var1 > var2 %}
{{ result }}
You haven’t really explained your goal. What you’re asking doesn’t really make sense without context.
Is your snippet an actual template you’re trying to create or an example of what you think you need? Are you in control of those variables? Will they come from sensor values? Is the comparison always >?
String concatenation is done with the ~ operator. You cannot evaluate a string with code in it. It’s generally speaking a huge security risk.
Not it’s not always >.
Those 2 variable come from
var1 an entity state
var2 comme from a customisation on the same entity that it been add when I want an alarm to be tested.
Var2 is like a condition for the trigger of the alarm.
If value is above 80.
it’s a customisation in home assistant, i’m adding attribute to and sensor and an automation validate if this condition is true, if so it’s trigger an alarm
OK, but this is all still very abstract and I highly suspect what’s been discussed here is unnecessarily convoluted. What is this alarm? What is your use case here?
