Dear all,
I hope you can help me as I am trying for hours now to set this up, but I am still failing:
My home assistant configuration contains a cover device, which can be controlled via the UI dashboard. It can be opened, closed or set to a provided position (in percent).
As I want to further process the value I would like to create a template helper sensor to just provide the value of the position of the cover.
Can you please support me by giving me hints on how the configuration of a template helper sensor would look like in YAML?
Thank you!
Best regards
Thomas
