Template in lovelace to start timer
Hello everyone, some time ago the button in Lovelace worked for me, but it seems something went wrong with the latest updates and now I see an error when executing it
          - type: custom:button-card
            entity: timer.socket_1
            tap_action:
              action: call-service
              service_data:
                entity_id: timer.socket_1
              service: timer.start
                duration: 00:{{ states.input_number.socket_1_timer.state | int }}:00
Failed to call service timer/start. offset 00:{{ states.input_number.socket_1_timer.state | int }}:00 should be format 'HH:MM', 'HH:MM:SS' or 'HH:MM:SS.F' for dictionary value @ data['duration']
The same template works fine in Automations or Developer tools
      - service: timer.start
Can anyone help me to find a mistake?
Templates are not supported in card actions, move your templating/logic to a script and call the script from the card action.
EDIT: See Below
True for core cards but it’s a custom card.
From memory the custom button card uses JavaScriot, not jinja.
Edit: yeah it has to be JavaScript, https://github.com/custom-cards/button-card#templates-support and I’m still not certain if the action supports it.
Thank you! I found the solution through simple automation rule after start timer
            tap_action:
alias: "timer"
  - platform: event
    event_type: timer.started
    event_data:
condition: []
mode: single
Thanks Tom, I had scrolled down just far enough that the type: line was not visible… :man_facepalming:
Custom Button does allow templates in actions:
You do have to use the annoying JS templates as mentioned. The templates seem to do some kind of auto-conversion for numeric states, but it will work as follows:
tap_action:
  service_data:
    duration: >
      [[[ return `00:${Math.floor(states['input_number.socket_1_timer'].state)}:00`;]]]
