I get the following error message when trying to use variables in a light template:
Invalid config for [light.template]: expected dictionary for dictionary value @ data[‘lights’][‘sofa_temp’]. Got '“{% set light_entity = “light.lampe_sofa” %}” “{% set brightness_entity = “input_number.brightness_lampe_sofa” %}” “{% set brightness = states(brightness_entity)|int %}” friendly_name: “Lampe ved sofaen template” value_template: “{{ states(light_entity) }}” level_template: “{{ state_attr(light_entity,'brightness')|int }}” effect_list_template: “{{ state_attr(light_entity, 'effect_list') }}” availability_template: “{{ states(light_entity) in ['on', 'off']}}” turn_on:\n service: light… (See ?, line ?).
Here’s my template code:
light:
lights:
sofa_temp: >-
{% set light_entity = "light.lampe_sofa" %}
{% set brightness_entity = "input_number.brightness_lampe_sofa" %}
friendly_name: "Lampe ved sofaen template"
value_template: "{{ states(light_entity) }}"
level_template: "{{ state_attr(light_entity,'brightness')|int }}"
availability_template: "{{ states(light_entity) in ['on', 'off']}}"
turn_on:
service: light.turn_on
brightness: "{{ brightness }}"
turn_off:
service: light.turn_off
The same template without variables doesn’t give an error message:
light:
lights:
sofa_temp:
value_template: "{{ states('light.lampe_sofa') }}"
level_template: "{{ state_attr('light.lampe_sofa','brightness')|int }}"
availability_template: "{{ states('light.lampe_sofa') in ['on', 'off']}}"
turn_on:
brightness: "{{ states('input_number.brightness_lampe_sofa')|int }}"
turn_off:
