Hello all,
actually I‘m struggling since few days with controlling RGBW LEDs.
First of all I’d like to describe shortly my LED setup in my house:
All RGBW LEDs are controlled by a DMX Controller which is connected to a WAGO PLC.
The PLC interfaces by Modbus with a Raspberry PI on which HA is running.
So my relevant Modbus/Light configuration looks as follows:
# PLC Modbus
modbus:
- name: Wago
type: tcp
host: 10.0.0.100
port: 502
switch:
# ______Modbus Switches_________
platform: modbus
scan_interval: 1
coils:
# * LED Relays *
- name: mb_wz_led_relay
hub: Wago
slave: 1
coil: 12405
- platform: modbus
scan_interval: 1
registers:
# * LED RGBW Values *
- name: mb_wz_led_r_value
hub: Wago
slave: 1
register: 13398
register_type: holding
data_type: uint
- name: mb_wz_led_g_value
hub: Wago
slave: 1
register: 13399
data_type: uint
- name: mb_wz_led_b_value
hub: Wago
slave: 1
register: 13400
data_type: uint
- name: mb_wz_led_w_value
hub: Wago
slave: 1
register: 13401
data_type: uint
light:
lights:
###_______WOHNZIMMER AMBIENTE______###
light_wz_led:
friendly_name: "Wohnzimmer Ambiente LED"
level_template: "{{ states.sensor.mb_wz_led_w_value.state|int }}"
value_template: "{{ is_state('switch.mb_wz_led_relay', 'on') }}"
color_template: "({{ states.sensor.mb_wz_led_r_value.state|int }}, {{ states.sensor.mb_wz_led_g_value.state|int }}, {{ states.mb_wz_led_b_value.state.state|int }})"
turn_on:
- service: switch.turn_on
entity_id: switch.mb_wz_led_relay
turn_off:
- service: switch.turn_off
set_level:
- service: modbus.write_register
data_template:
hub: Wago
unit: 1
address: 13401
value: "{{ brightness }}"
set_color:
data_template:
hub: Wago
unit: 1
address: 13398
value: "{{ h }}" #here I need the red value instead of the h
data_template:
hub: Wago
unit: 1
address: 13399
value: "{{ s }}" #here I need the green value instead of the s
data_template:
hub: Wago
unit: 1
address: 13400
value: "{{ s }}" #here I need the blue value instead of the s
So far I’m able to switch on/off the LEDs but not able to control the them with the right color. The main problem is that the template light provides the colors in HSB (hue, saturation, brightness) and I need them as RGB to write the values in the Modbus register.
I have to say that I’m quite new to HA and yaml (started just few days ago) and have no clue how I can solve this issue.
I found a the script to convert HSB to RGB (Using HSV / HSB to set colored lights) but no idea how I can include this in my configuration.yaml file.
It would be great when someone can tell me if I’m total wrong with the light template for this case or how I must adjust it to work.
Many thanks in advance for your help!
