Template not firing?
Hi looking for some help.
So I have an mqtt switch and when it turns on, I want to issue a second mqtt command, I know I could do this in an automation but I really want this it be part of the switch setup.
So from the template example Template - Home Assistant
I am trying this
        mqtt:
         switch:
         - unique_id: ideal_thermostat_disable
           command_topic: "IdealBoiler/set/idealC40/command"
           availability:
            - topic: "IdealBoiler/value/idealC40"
           payload_on: "CS=4.0"
           payload_off: "CS=0.0"
           state_topic: "IdealBoiler/value/idealC40/TSet"
           value_template: "{% if value=='4.00' %}on{% else %}off{% endif %}"
           state_on: "on"
           state_off: "off"
           optimistic: false
           retain: false
        template:
           select:
              unique_id: diable_CH
              state: "{{ states.switch.ideal_thermostat_disable }}"
              options: "{{ ['on'] }}"
              select_option:
                - service: mqtt.publish
                    payload: "CH=0"
But the template never fires, is this a bug or am I doing something wrong?
You are putting the template integration inside the mqtt integration. This is not allowed. In your configuration.yaml file these two integrations must be completely separate and have the same indentation.
Like this:
mqtt:
template:
Not like this:
mqtt:
  template:
Sorry @tom_l , that was a copy paste error, corrected, it is at the same level, the validator produces no errors etc, just doesn’t fire.
There is no template select. https://www.home-assistant.io/integrations/template/
And even if there were the select option service does not allow you to execute other services, only to make an option selected.
You could hide your mqtt switch and use a template switch. The turn on and turn off actions of the template switch allow more than one service.
switch:
    switches:
      thermostat_disable_plus:
        name: Thermostat Disable Plus
        value_template: "{{ is_state('switch.ideal_thermostat_disable', 'on') }}"
        turn_on:
          - service: switch.turn_on
              entity_id: switch.ideal_thermostat_disable
              payload: "CH=0"
        turn_off:
          service: switch.turn_off
Thank you I’ll give that a try, but I was only going of the page Template - Home Assistant you referred to, it does show a template select at the bottom of the page:
STATE BASED SELECT - CONTROL DAY/NIGHT MODE OF A CAMERA
This show how a state based template select can be used to call a service.
template:
  select:
    - name: "Porch Camera Day-Night Mode"
      unique_id: porch_camera_day_night_mode
      state: "{{ state_attr('camera.porch_camera_sd', 'day_night_mode') }}"
      options: "{{ ['off', 'on', 'auto'] }}"
      select_option:
        - service: tapo_control.set_day_night_mode
            day_night_mode: "{{ option }}"
            entity_id: camera.porch_camera_sd
You’re absolutely right. I misread that.
A template switch still makes more sense, unless you have other options you want to include later?
No works ok, just strange the select did not fire?
What does the select do when the switch is off?
You need more options for it to be valid. Even if you never use that option.
Also your state template is invalid. Try this
        template:
           select:
              state: "{{ states('switch.ideal_thermostat_disable') }}"
              options: "{{ ['on', 'off'] }}"
              select_option:
                    payload: "CH=0"
You would also need to construct a service template to only publish the packet for the off state.
I’ll give this a try as well and get back to you thank you!!
So I tried the above, it doesn’t fire the service either, not for either on or off must be a bug?
Has this been confirmed as a bug? I can’t for the life of me get my template select to trigger anything under the select_option either.
edit: seems to be only when it’s updated by state: - would that be expected?
That’s how template entities work, unless you omit the value_template/state and allow optimistic mode.
