Hello there,
I have zigbee bulbs that don’t work right away - I’m sure this will be fixed some way and I’ll open a dedicated subject about these enki bulbs (issue has already hapenned for ikea bulbs, so…) , but for now I’m wondering about HASS configuration.
To make those bulbs work , I had to make sure the brightness changes happen with a 0.001 transition. In order to do that, I created a"template light" for which I have several questions :
e27_salon1:
friendly_name: "Salon 1"
value_template: >-
{% if is_state('light.ampoule_e27_salon1_level_light_color_on_off', 'on') %}
on
{% else %}
off
{% endif %}
color_template: "{{ state_attr('light.ampoule_e27_salon1_level_light_color_on_off', 'hs_color') }}"
white_value_template: "{{ state_attr('light.ampoule_e27_salon1_level_light_color_on_off', 'white_value') }}"
level_template: >-
{{ state_attr('light.ampoule_e27_salon1_level_light_color_on_off', 'brightness') }}
{% else %}
0
{% endif %}
turn_on:
service: light.turn_on
entity_id: light.ampoule_e27_salon1_level_light_color_on_off
turn_off:
service: light.turn_off
set_level:
data_template:
brightness: "{{ brightness }}"
transition: 0.001
set_temperature:
data_template:
color_temp: "{{ color_temp }}"
transition: 0.2
set_color:
data_template:
hs_color:
- "{{ h }}"
- "{{ s }}"
transition: 2
Now the questions:
1 : as you can see, I’m repeating again and again the light entity ID : when I added a 2nd bulb… I copy/pasted all of this, and had to change the entity ID everywhere in the new template… same for 3rd bulb. And when I want to change something, I’ll have to edit all 3 (or more) template lights… Looking at blueprints, it looks like the perfect thing to “instantiate” a specific template, but I think blueprints only are meant for automations ? So : is there a way to have “custom templates” or template blueprints or templates of templates where I would only have to change on thing like a “target”, and where the other properties would be the same as the model ? Or maybe I’m not doing the thing correctly, if so I’m all ears
2 : if not : copy/pasting the light id everywhere is not very nice… is there a way for me to use some “variable” in the template and to refer to that same variable below ?
Thanks && regards (and thanks for this awwwwwsome piece of software ! :] )
