Template result filter
Hi
I use this template to put any entity in this device in the template to back one specific entity binary_sensor.bluetooth_hub_connected to know the state of the device is connected or not.
but I can’t filter the result :upside_down_face:
{{ device_entities(device_id('sensor.bluetooth_hub_ip')) }}
result is
  "button.bluetooth_hub_restart",
  "sensor.bluetooth_hub_wifi_dbm",
  "sensor.bluetooth_hub_wifi_channel",
  "sensor.bluetooth_hub_wifi_percentage",
  "sensor.bluetooth_hub_illuminance",
  "sensor.bluetooth_hub_uptime",
  "sensor.bluetooth_hub_ip",
  "sensor.bluetooth_hub_wifi_ssid",
  "light.bluetooth_hub_rgb",
  "binary_sensor.bluetooth_hub_connected",
  "binary_sensor.bluetooth_hub_button",
  "sensor.xiaomi_mi_scale_weight",
  "sensor.xiaomi_mi_scale_impedance"
I need to filter the list
Why not just do this?
{{ states('binary_sensor.bluetooth_hub_connected') }}
only show me this
My template returns the state of the entity, not the entity id. That’s what you want isn’t it?
To know if it is connected or not?
I know this my goal extrct binary_sensor.bluetooth_hub_connected when I use Automation in the blueprint
blueprint:
  name: Motion-activated Light (multiple) for ESPHome
  description: Turn on a light when motion is detected.
  domain: automation
  input:
    motion_entity:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
          multiple: true
    light_target:
      selector:
          entity:
            domain: light
    Node_Connected:
      name: Node Connected
      description: Wait for Node Connected before activated light.
      selector:
        entity:
          integration: esphome
          device_class: connectivity
    no_motion_wait:
      description: Time to leave the light on after last motion is detected.
      default: 120
      selector:
        number:
          min: 0
          max: 1800
          unit_of_measurement: seconds
mode: restart
max_exceeded: silent
  platform: state
  entity_id: !input motion_entity
  to: "on"
  - wait_template: "{{ is_state(!input Node_Connected, 'on') }}"
    continue_on_timeout: false
  - service: light.turn_on
    target: !input light_target
  - wait_for_trigger:
      platform: state
      to: "off"
  - delay: !input no_motion_wait
  - service: light.turn_off
instead, use
    Node_Connected:
      selector:
        entity:
when I select light its pickup this entity because the light in the same node
all that because we have electricity issues some nodes need time to back online
variables:
  Node_Connected: !input light_target "{ after filter result }"
- wait_template: "{{ is_state(Node_Connected, 'on') }}"
and remove part off
Node_Connected:
      selector:
        entity:
