1mfaasj
(Bowa)
January 13, 2024, 1:49pm
1
I dont get it. I can’t get it gone to convert the result of the template into an amount with 2 digits after the comma
the template:
"{{ ( states('sensor.scrape')|float(0) - states('input_number.mynumber')|float(0) ) / states('input_number.mynumber')|float(0) * 100 | round(2) }}"
I thought the round(2)
was meant to short numbers?
sensor.scrape gives this back:
108,32 €
and input_number.mynumber:
96.37 €
the result is:
"12.400124520078851"
But I was hoping for "12.40"
Even if I try to add round(2)
after each sensor it gives the same result.
Can anyone help me?
petro
(Petro)
January 13, 2024, 1:50pm
2
You’re only rounding the 100. Wrap the equation in parenthesis and round that.
1mfaasj
(Bowa)
January 13, 2024, 1:54pm
3
Hi Petro what do you mean? where to put he “”?
Even if I put the round after the sensors, it gives the same result. for instance
"{{ ( states('sensor.scrape')|float(0) | round(2) - states('input_number.mynumber')|float(0) | round(2) ) / states('input_number.mynumber')|float(0) * 100 }}"
or
"{{ ( states('sensor.scrape')|float(0) | round(2) - states('input_number.mynumber')|float(0) ) / states('input_number.mynumber')|float(0) * 100 }}"
"{{ ((states('sensor.scrape')|float(0) - states('input_number.mynumber')|float(0) ) / states('input_number.mynumber')|float(0) * 100) | round(2) }}"
jchh
((not John))
January 13, 2024, 2:06pm
5
Parenthesis means brackets (not quotes).
Try this:
"{{ ( (states('sensor.scrape')|float(0) - states('input_number.mynumber')|float(0) ) / states('input_number.mynumber')|float(0) * 100) | round(2) }}"
Edit: @mobile.andrew.jones beat me to it!
At least we both came up with the same answer, which adds confirmation that it’s the right way to achieve it
1mfaasj
(Bowa)
January 13, 2024, 2:31pm
7
thanks all three. its working now!
petro
(Petro)
January 13, 2024, 4:34pm
8
FYI
Brackets → [ ]
Parentheses → ( )
Quotes → " "
or ' '
jchh
((not John))
January 13, 2024, 5:32pm
9
Is that a Python thing? …where I am from “round brackets” is the common description for ( )
and “square brackets” for [ ]
