Template Sensor - Blank space
i will control my QNAP with the existing sensors.
And now i will show the ip.
This is a Attripute of the EHT0
sensor.n0011100001_network_up_eth0
  "Mask": "255.255.255.0",
  "Max Speed": 1000,
  "Packets (Err)": 5,
  "icon": "mdi:upload",
  "Packets (TX)": 20951319,
  "friendly_name": "N0011100001 Network Up (eth0)",
  "IP Address": "10.10.100.60",
  "unit_of_measurement": "MB/s",
  "Packets (RX)": 26744618
so i create a sensor template:
    sensors:
     nas_sensor_uptime:
       value_template: '{{ states.sensor.n0011100001_status.attributes.Uptime }}'
     nas_ip:
       value_template: '{{ states.sensor.n0011100001_network_up_eth0.attributes.IP Address }}'
Uptime works but the IP Adress not… i think it’s the blank…
LOG:
2017-07-05 13:20:43 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.template]: invalid template (TemplateSyntaxError: expected token 'end of print statement', got 'Address') for dictionary value @ data['sensors']['nas_ip']['value_template']. Got '{{ states.sensor.n0011100001_network_up_eth0.attributes.IP Address }}'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
Have someone the solution?
thanks for you help!
Hi @Schmidij_ch, you can play with this in Developer Tools/Templates.
When i try:
{% set DICT = {
  "Max Speed": 1000,
  "Packets (Err)": 5,
{{ DICT["IP Address"] }}
it returns: “10.10.100.60”
So maybe use:
value_template: '{{ states.sensor.n0011100001_network_up_eth0.attributes["IP Address"] }}'
thx this works :slight_smile:
