Hi folks,
I have this interesting situation w/template(s). I am trying to explain this through my 2 examples in place:
So I have both of the following configurations in configuration.yaml in place:
1:
template:
- binary_sensor:
- name: site.people_home
state: >
{{ is_state('person.gilf0y', 'home')
or is_state('person.wifey', 'home')
or is_state('binary_sensor.site_sensor_door', 'on') }}
2:
template:
- sensor:
- name: site.outerdoor_state
state: >
{% if is_state('binary_sensor.site_sensor_outerdoor', 'off') %}
armed
{% elif is_state('binary_sensor.site_sensor_outerdoor', 'on') %}
disarmed
{% else %}
failed
{% endif %}
So - I can get the first (1) sensor entity I created visible everywhere and its usable. Its pretty much copy & paste from HA template documentation. So that works.
Based on that, I figured out that why not to create sensor entity (2) that would tell me things in bit different words I need in further processing. That site.outerdoor_state never shows up in anywhere, not on developer entities or logs either. It seems to be correctly done, since no errors. I copied most of the stuff so I bet someone is using alike.
HOWEVER - that works on Template “tester” under developer tools.
Someone able to tell what ‘magic’ is needed to make such sensor entity visible on entity lists etc? I tried to change between binary/sensor etc. - no dice. Help appreciated
