Template Sensor exclude value
Hey there!
I have defined two template min/max sensors in my configuration to get the min and max temperature from my weather station including the last 24 hours.
But i noticed, that during my nightly backup and restart the temperature drops to 0 for a second, so either my min or my max sensor is always 0.
How am i able to exclude the value 0 from these two sensors?
This would be my config for them:
- platform: statistics
  entity_id: sensor.aussentemperatur
  name: Außentemperatur Statistik
  sampling_size: 1000
  max_age: "24:00:00"
  precision: 2 #default=2.
  sensors:
    aussentemperatur_temp_max:
      value_template: "{{ state_attr('sensor.aussentemperatur_statistik', 'max_value') }}"
    aussentemperatur_temp_min:
      value_template: "{{ state_attr('sensor.aussentemperatur_statistik', 'min_value') }}"
Hope someone has a solution for me :slight_smile:
Greetings
This will keep the last value if the new value is 0.
  sensors:
      value_template: >
        {% set max = state_attr('sensor.aussentemperatur_statistik', 'max_value')|float(0) %}
        {{ max if max != 0 else states('sensor.aussentemperatur_temp_max') }}
      value_template: >
        {% set min = state_attr('sensor.aussentemperatur_statistik', 'min_value')float(0) }}
        {{ min if min != 0 else states('sensor.aussentemperatur_temp_min') }}
You might want to add a friendly_name, unit_of_measurement and a state_class to each too.
  sensors:
      friendly_name: "Außentemperatur Max"
      unit_of_measurement: "°C"
      state_class: measurement
      value_template: >
      friendly_name: "Außentemperatur Min"
      value_template: >
        {% set min = state_attr('sensor.aussentemperatur_statistik', 'min_value')|float(0) }}
One issue is that this is outdoor temperature and outdoor temperature could be 0.
Can’t updates be discarded during a restart somehow? “If uptime > 1”?
That looks great thank you!
But I’m getting the following error, when checking the configuration:
Invalid config for [sensor.template]: invalid template (TemplateSyntaxError: expected token 'end of statement block', got 'float') for dictionary value @ data['sensors']['aussentemperatur_temp_min']['value_template']. Got "{% set min = state_attr('sensor.aussentemperatur_statistik', 'min_value')float(0) }} {{ min if min != 0 else states('aussentemperatur_temp_min') }}\n". (See ?, line ?).
Do you know why?
@Hellis81 No that’s not the problem, it’s always at 3am, when the backup starts and the real temperature is not going from 5 to 0 to 5 degrees in a second.
In the min sensor, this:
Should be:
)|float(0)
The time is irrelevant. Not sure why it would have to be 5 degrees either.
Whenever the temperature is 0 then it will be discarded.
If the temperature is 0 the whole day then you won’t get any data for that day.
Thanks that worked!
But it seems that i have another problem now, maybe it’s after the update to 2021.12, the statistics sensor does not have a max_/min_value attribute anymore, seems like i have to make two statistic sensor with state_characteristic: value_min/_max configuration.
But i don’t know how to make a template sensor from these sensors, because template sensors are made from attributes or? That’s why you write them like this state_attr('sensor.aussentemperatur_statistik', 'min_value').
Edit:
Nevermind, got it working
      friendly_name: "Hoch (24h)"
      #      state_class: measurement
      value_template: >
        {% set max = states('sensor.aussentemperatur_statistik_max')|float(0) %}
        {{ max if max != 0 else states('aussentemperatur_temp_max') }}
changed state_attr with states
Againg thank for your help! :slight_smile:
@tom_l Could you please help me once more?
These are the statistic sensors in my sensor.yaml:
  name: Außentemperatur Statistik Max
  sampling_size: 1000
  max_age:
    hours: 24
  precision: 2
  state_characteristic: value_max
  name: Außentemperatur Statistik Min
  sampling_size: 1000
  max_age:
    hours: 24
  precision: 2
These are the template sensors in my template.yaml:
- sensor:
    - name: "Hoch (24h)"
      state: >
    - name: "Tief (24h)"
      state: >
        {% set min = states('sensor.aussentemperatur_statistik_min')|float(0) %}
They are working fine, now the temperature at my house is 5.5 degrees, template sensor displays that.
But if i’m setting the value to 0 or 0.0 the sensor says unknown. Same for the min sensor.
Thought, that the max sensor should stay at 5.5?
Looks like you have changed to the new template format too. This takes the entity id from the name. So sensor.hoch_24h and sensor.tief_24h I think. Check this in the Developer Tools / States page. Then replace the sensors that hold the last measurement in your templates:
- sensor:
      state: >
        {{ max if max != 0 else states('sensor.hoch_24h') }}
      state: >
        {{ min if min != 0 else states('sensor.tief_24h') }}
Yeah, i thought i need to do it anyway, so why not now^^.
But it worked, thanks again for your help :slight_smile: !
The new format has pros and cons. Mostly pros. It’s worth doing.
Also I actually missed the sensor. part before aussentemperatur in the original templates. I fixed it up so it does not confuse anyone else.
hello me after the last update the old configuration does not work
  • platform: template
    sensors:
    teplota_vonku_max:
    value_template: “{{ state_attr(‘sensor.teplota_vonku_24h’, ‘max_value’) }}”
    teplota_vonku_min:
    value_template: “{{ state_attr(‘sensor.teplota_vonku_24h’, ‘min_value’) }}”
I tried yours and I have an error in the log
error
Invalid config for [sensor.template]: [state_class] is an invalid option for [sensor.template]. Check: sensor.template->sensors->teplota_vonku_24max->state_class. (See ?, line ?).
    entity_id: sensor.teplota_vonk
    name: Teplota vonku 24h
    sampling_size: 1000
    max_age: "24:00:00"
    sensors:
      teplota_vonku_24max:
        friendly_name: "teplota vonku 24hmax"
        value_template: >
          {% set max = state_attr('teplota_vonku_24max')|float(0) %}
          {{ max if max != 0 else states('sensor.teplota_vonku_24h') }}
      teplota_vonku_24min:
        friendly_name: "teplota vonku 24hmin"
        value_template: >
          {% set min = state_attr('teplota_vonku_24min')|float(0) %}
          {{ min if min != 0 else states('sensor.teplota_vonku_24h') }}
