Template sensor help needed - current month,last month, estimated usage?
I need help getting my template sensor to only show data for the current month, and another to show data for last month. (Calculating power usage of appliances and lights until I get my energy monitoring setup going, and would like to show current usage vs previous month)., I then need to work out the daily usage of the current month, to estimate full usage at month end…
I also have a Sonoff POW R2 running tasmota and need to setup a template sensor (also using the current and last month) using the MAX of the Energy today mqtt sensor I defined…
Any help would be appreciated…
or
can get you what you are looking for
