i am trying to make some of the attributes in this template editable from the frontend, but i cant get the syntax correct.
its the states.input_number.periode_1_antal_timer.state. that troubles me.
template:
- sensor:
# The actual cheapest hour sensor. If multiple entries are required, copy and set unique_id and configure attributes.
- name: "Billig_el_periode_1"
unique_id: billig_el_periode_1
device_class: timestamp
state: >
{%- set sensor = (this.attributes.get('sensor', 'sensor.nordpool') | string) -%}
{%- set numberOfSequentialHours = (this.attributes.get('number_of_sequential_hours',1) | int) -%}
{%- set lastHour = (this.attributes.get('last_hour',23) | int) -%}
{%- set firstHour = (this.attributes.get('first_hour', 0) | int) -%}
{%- set startingToday = (this.attributes.get('starting_today', false) | bool) -%}
{%- if state_attr(sensor, 'tomorrow_valid') == true -%}
{%- set arr = state_attr(sensor, 'today') + state_attr(sensor, 'tomorrow') -%}
{%- set ns = namespace(counter=0, list=[], cheapestHour=today_at("00:00"), cheapestPrice=999.00) -%}
{%- if startingToday == true -%}
{%- set ns.starting = firstHour -%}
{%- else -%}
{%- set ns.starting = firstHour + 24 -%}
{%- endif -%}
{%- set ns.ending = lastHour + 24 -%}
{%- for i in range(ns.starting + numberOfSequentialHours, ns.ending+1) -%}
{%- set ns.counter = 0.0 -%}
{%- for j in range(i-numberOfSequentialHours, i) -%}
{%- set ns.counter = ns.counter + arr[j] -%}
{%- endfor -%}
{%- set ns.list = ns.list + [ns.counter] -%}
{%- if ns.counter < ns.cheapestPrice -%}
{%- set ns.cheapestPrice = ns.counter -%}
{%- set ns.cheapestHour = today_at("00:00") + timedelta( hours = (i - numberOfSequentialHours)) -%}
{%- endif -%}
{%- endfor -%}
{{ ns.cheapestHour }}
{%- set ns.cheapestPrice = ns.cheapestPrice / numberOfSequentialHours -%}
{%- endif -%}
attributes:
# CHANGE-ME: Set your personal configurations in here {{ states('input_number.periode_1_antal_timer')| float }} (states('input_number.periode_1_antal_timer'))
number_of_sequential_hours: states.input_number.periode_1_antal_timer.state # Amount of sequantial cheapest hours in search
first_hour: 00 # Search starting hour
last_hour: 23 # Search ending hour
starting_today: false # Is the first_hour today (true / false). If false, first_hour needs to be before last_hour.
sensor: sensor.nordpool # Nord pool sensor id. Check it ouf from your integrations page!
fail_safe_starting: '00:00' # If nordpool fetch fails, starting time to make the calendar entry
these are the ones i have made input_numbers for. but i just cant get it to compute…
petro
(Petro)
June 6, 2023, 1:34pm
3
number_of_sequential_hours: >
{{ states('input_number.periode_1_antal_timer') }}
Keep in mind that this most likely will not work on your main sensor because it will always resolve after the main state is resolved.
petro
(Petro)
June 6, 2023, 1:44pm
4
The only proper way to handle this IMO…
template:
- trigger:
- platform: state
entity:
- sensor.nordpool
- input_number.periode_1_antal_timer
- input_number.periode_1_antal_first_hour
- input_number.periode_1_antal_last_hour
variables:
first_hour: >
{{ states('input_number.periode_1_antal_first_hour') }}
last_hour: >
{{ states('input_number.periode_1_antal_last_hour') }}
- sensor:
state: >
{%- if starting_today -%}
{%- set ns.starting = first_hour -%}
{%- else -%}
{%- set ns.starting = first_hour + 24 -%}
{%- endif -%}
{%- set ns.ending = last_hour + 24 -%}
{%- for i in range(ns.starting + number_of_sequential_hours, ns.ending+1) -%}
{%- for j in range(i-number_of_sequential_hours, i) -%}
{%- endfor -%}
{%- set ns.cheapestHour = today_at("00:00") + timedelta( hours = (i - number_of_sequential_hours)) -%}
{%- endif -%}
{%- endfor -%}
{%- set ns.cheapestPrice = ns.cheapestPrice / number_of_sequential_hours -%}
{%- endif -%}
I didn’t go through the code. TBH, it seems alittle verbose. I recall doing something similar to this and it wasn’t this complicated.
thanks. i did not write the code. maybe thats the problem.
thanks i will look into your solution.
cant get it working. damn!
- trigger:
- platform: state
entity_id:
- sensor.nordpool
- input_number.periode_1_start_tid
- input_number.periode_1_slut_tid
variables:
first_hour: >
{{ states('input_number.periode_1_start_tid') }}
last_hour: >
{{ states('input_number.periode_1_slut_tid') }}
- sensor:
state: >
{%- else -%}
{%- endif -%}
{%- endfor -%}
{%- endif -%}
{%- endfor -%}
{%- endif -%}
keep getting this.
Stopped because an error was encountered at 6. juni 2023 kl. 21.54.49 (runtime: 0.02 seconds)
Error rendering data template: ValueError: Template error: float got invalid input ‘None’ when rendering template ‘{%- set sensorId = ‘sensor.billig_el_periode_1’ -%} {{ (as_timestamp(states(sensorId)) + (3600 * state_attr(sensorId, ‘number_of_sequential_hours’) | float)) | timestamp_local }}’ but no default was specified
the first part uses variables: and the second uses atrributes. hmm. is that campateble?
petro
(Petro)
June 7, 2023, 9:23am
8
None of that code is in what I pasted for you to use.
I know but the sensor.billig_el_periode_1 is not working and the error is from the automation that processes the sensor. there is no info in the sensor …
petro
(Petro)
June 7, 2023, 11:02am
10
If you’re only getting an error from the automation, then sensor.billig_el_periode_1 is working. That error is 100% unrelated to the sensor. It’s a code error in your automation.
i use the same automation for a sensor with hardcodes values. it works. and in developer / states i can see the sensor is empty. i have it running on 2 other servers and works there too. i just need to make it easier to change for people without coding experience. (as myself apparently)…
i get this error from the sensor code:
Template variable error: ‘sensor’ is undefined when rendering ‘{%- if state_attr(sensor, ‘tomorrow_valid’) == true -%} {%- set arr = state_attr(sensor, ‘today’) + state_attr(sensor, ‘tomorrow’) -%} {%- set ns = namespace(counter=0, list=[], cheapestHour=today_at(“00:00”), cheapestPrice=999.00) -%} {%- if starting_today -%} {%- set ns.starting = first_hour -%} {%- else -%} {%- set ns.starting = first_hour + 24 -%} {%- endif -%} {%- set ns.ending = last_hour + 24 -%} {%- for i in range(ns.starting + number_of_sequential_hours, ns.ending+1) -%} {%- set ns.counter = 0.0 -%} {%- for j in range(i-number_of_sequential_hours, i) -%} {%- set ns.counter = ns.counter + arr[j] -%} {%- endfor -%} {%- set ns.list = ns.list + [ns.counter] -%} {%- if ns.counter < ns.cheapestPrice -%} {%- set ns.cheapestPrice = ns.counter -%} {%- set ns.cheapestHour = today_at(“00:00”) + timedelta( hours = (i - number_of_sequential_hours)) -%} {%- endif -%} {%- endfor -%} {{ ns.cheapestHour }} {%- set ns.cheapestPrice = ns.cheapestPrice / number_of_sequential_hours -%} {%- endif -%}’
maybe this needs something? sensor: sensor.nordpool?
petro
(Petro)
June 7, 2023, 8:22pm
13
Remove this dash completely. Make sure the word sensor has the same number of spaces as the trigger:
line above. i.e. same indentation level. Treat -
as a “space” when counting in front of trigger.
that fixed the error in the log . state is unavalible. do i need to wait for a change in the variables?
petro
(Petro)
June 7, 2023, 8:29pm
15
it shouldn’t be unavailable. Only unkonwn if it’s waiting for a state. Post the configuration you’re using
nordpool is fine. i have values in the sensor.nordpool
i am having really bad yaml karma these days
thanks for your time and help. i think it will work now. will have to wait for tomorrow to see…
-andy
petro
(Petro)
June 8, 2023, 11:12am
19
Then when you change one of the input_numbers or when sensor.nordpool updates, the template sensor will provide a valid value assuming that whoever wrote that code built it well.
petro
(Petro)
June 8, 2023, 11:13am
20
FYI, people do not see your responses when you reply to the thread.
You’ll get better support.
