Template Sensor to check how many lights are on 2025
I need a bit of help to change the count_lights_on: sensor that I have in the sensor yaml, to make it compatible with the new changes.
    sensors:
     count_lights_on:
      friendly_name: "All Lights"
      unit_of_measurement: ''
      value_template: >-
          states.light
          | selectattr('state', 'eq', 'on')
          | rejectattr('attributes.is_group', 'eq', true)
          | rejectattr('entity_id', 'is_hidden_entity')
          | rejectattr('attributes.entity_id', 'defined')
          | rejectattr('object_id', 'search', 'air_quality')
          | rejectattr('entity_id', 'in',  ['light.led_occupancy_gpio_hallway', 'light.tagreader_led'])
          | list
          | count
This still working, but I got a warning that I have to change it, otherwise will stop working.
I tried to replace it with
    sensors:
     count_lights_on:
      state: "{{ \n  states.light\n  | selectattr('state', 'eq', 'on')\n  | rejectattr('attributes.is_group',
      'eq', true)\n  | rejectattr('entity_id', 'is_hidden_entity')\n  | rejectattr('attributes.entity_id',
      'defined')\n  | rejectattr('object_id', 'search', 'air_quality')\n  | rejectattr('entity_id',
      'in',  ['light.led_occupancy_gpio_hallway', 'light.tagreader_led']) \n  | list\n
      \ | count          \n}}"
But I get a configuration error
Configuration warnings
Invalid config for ‘template’ from integration ‘sensor’ at sensor.yaml, line 71: required key ‘value_template’ not provided Invalid config for ‘template’ from integration ‘sensor’ at sensor.yaml, line 74: ‘state’ is an invalid option for ‘sensor.template’, check: sensors->count_lights_on->state
You still have this in the sensor: integration. It needs to be in template: integration.
Read thru this and then ask further questions there…
There is a custom integration you can install to fix this automagically I believe.
The legacy platform: template syntax for sensor is being removed. Please migrate count_lights_on to the modern template syntax.
Step 1 - Remove legacy configuration
Remove the count_lights_on template definition from the configuration.yaml sensor: section.
Note: If you are using sensor: !include <filename>.yaml in configuration.yaml, remove the sensor definition from the included <filename>.yaml.
Step 2 - Add the modern configuration
template:
- sensor:
  - unit_of_measurement: ''
    default_entity_id: sensor.count_lights_on
      \ | count          \n}}"
This is the message.
This stops working in version 2026.6. Please address before upgrading.
I got it fixed. I removed it from sensor.yaml, I added template: !include templates.yaml in config.yaml and created the templetes.yaml and the code is
- sensor:
    - name: "Count Lights On"
      unique_id: count_lights_on
      unit_of_measurement: ""
      state: >
          states.light
          | list
          | count
besides the migration, why not add a label to all individual lights, and use label_entities() in the template.
Way easier :wink:
that template is so 2017…
Where do you add the label_entities()?
In the UI entities dashboard
I see what you mean. Where it say add lablel? create a label say lights?
Or obsolete AI slurp, regurgitated without consideration of many subsequent changes in HomeAssistant…
You guys saying that my template is obsolete? :grimacing: should I use labels instead?
Well, you could yes.
It will make it a 1 liner.
And yes, label light would do it . You can add more, like inside outside, whatever.
And make easy templates :wink:
{{label_entities('light')
             |select('is_state','on')|list|count}}
or
{{union(label_entities('binnen_lamp'),label_entities('buiten_lamp'))
which was done previously like:
{{['binnen_lamp','buiten_lamp']
   |map('label_entities')
   |sum(start=[])
   |list|count}}
still works of course :wink:
That is not really required…
Being that unfriendly I mean
