I am trying to combine a Yeelight which has 2 modes (normal mode and night mode) into one template light. The idea is that from Brightness 1-30% of the template light the night mode turns on and scales from 1 - 100%, from 31% to 100% of the template light the normal mode turns on and scales from 1 - 100%. I can’t use the Lightener HACS addon, as it turns off the not used lights - unfortunately a turn off service call to either of the 2 modes turns off the whole lamp.
I especially have trouble to understand the level_template and value_template.
Would be great if someone could give me some pointers, thanks a lot in advance!
light:
lights:
ceiling_light:
friendly_name: "Ceiling Light"
level_template: >-
{% set brightness1 = state_attr('light.yeelight_ceiling4_0x7d79fa4_nightlight', 'brightness') | default(0) %}
{% set brightness2 = state_attr('light.yeelight_ceiling4_0x7d79fa4', 'brightness') | default(0) %}
{% if brightness1 > 0 %}
{{ (brightness1 / 255 * 30) | round(0) }}
{% elif brightness2 > 0 %}
{{ 30 + (brightness2 / 255 * 70) | round(0) }}
{% else %}
0
{% endif %}
turn_on:
service: light.turn_on
entity_id:
- light.yeelight_ceiling4_0x7d79fa4_nightlight
turn_off:
service: light.turn_off
entity_id:
set_level:
service: script.set_ceiling_lights
brightness: "{{ brightness }}"
entity_id:
set_level:
script:
set_ceiling_lights:
alias: Set Ceiling Lights
icon: mdi:ceiling-fan-light
fields:
brightness:
required: true
sequence:
- if:
- alias: Brightness < 30%
condition: template
value_template: '{{ int(brightness) < 76 }}'
then:
- service: light.turn_on
brightness: '{{ (int(brightness / 2.55) * 3) }}'
entity_id: light.yeelight_ceiling4_0x7d79fa4_nightlight
else:
brightness: '{{ ((int(brightness -30 / 2.55)) * 3) }}'
