Template Switch help
Hi, I need help with a template switch I can’t get working.
    switches:
      opensprinkler_rain_delay:
        value_template: "{{ is_state('binary_sensor.rain_delay', 'on') }}"
        turn_on:
          service: shell_command.set_rain_delay_2
            delay_in_days: "{{ states('input_number.rain_delay_in_days') | int }}"
        turn_off:
            delay_in_days: 0
It’s the ‘turn on’ service that doesn’t work. It’s calling the shell command ->
set_rain_delay_2: “curl -G -v http://x.x.x.x/cv --data-urlencode pw=password --data-urlencode rd={{ delay_in_days }}”
I think the shell command is OK, as I can call it from the service panel with data {“delay_in_days”:“7”}, and it works.
Number input slider looks like this ->
  rain_delay_in_days:
    initial: 0
    min: 0
    max: 7
    step: 1
Log ->
Error running command: curl -G -v http://x.x.x.x/cv --data-urlencode pw=password --data-urlencode rd={{ delay_in_days }}, return code: 3
NoneType: None
Any help appreciated
You need to use data_template instead of data because, well, you’re using a template. :wink:
        turn_on:
          data_template:
Oh of course, so I was just passing a string, thanks heaps
