Template switch not working even though scripts do
Can anyone tell me why this does not work? The scripts both work and the boolean tests out OK in the template editor. It was working when I set it up but for the life of me, I can’t see what could be wrong.
    switches:
      lounge_heat_pump:
        value_template: "{{ is_state('input_boolean.lounge_heat_pump', 'on') }}"
        turn_on:
            entity_id: input_boolean.lounge_heat_pump
          - service: script.turn_on
            entity_id: script.lounge_aircon_on
        turn_off:
          - service: input_boolean.turn_off
            entity_id: script.lounge_aircon_off
try :
    switches:
      lounge_heat_pump:
        turn_on:
          - service: script.lounge_aircon_on
        turn_off:
          - service: script.lounge_aircon_off
I’m a dumb arse! I was using the input_boolean instead of the newly created switch! Not enough water in my whiskey!
