Template Switch Only Logging "Turning ON", Not "Turning OFF"
Hey folks, I’m running into a weird issue with a template switch in ESPHome.
Here’s what I’m trying to do:
  • I have a global variable allow_sleep (type: bool)
  • A template switch called sleep_allowed toggles that variable
  • Everything works fine when I turn the switch on — I see this in the logs:
[switch:012] 'sleep_allowed' Turning ON.
BUT when I turn it off, I get [switch:012] 'sleep_allowed' Turning ON.
Here’s the relevant config:
globals:
  - id: allow_sleep
    type: bool
    restore_value: yes
    initial_value: 'false'
switch:
    restore_state: true
    turn_on_action:
      - lambda: |-
          id(allow_sleep) = true;
      - logger.log: "Sleep allowed: ON"
    turn_off_action:
      - lambda: |-
          id(allow_sleep) = false;
      - logger.log: "Sleep allowed: OFF"
I’ve tried:
  • Testing directly from ESPHome dashboard
  • Watching live logs
  • Rebooting and reflashing
  • Checking YAML formatting and indentation
  • Verifying there’s no other switch or automation conflicting with sleep_allowed
Still no joy. The turn_off_action just seems to never run.
Anyone seen this before or have any ideas?
Thanks in advance :pray:
Why do you need both the global AND the switch which has state that should be what the global is?
You should also see this:
If not, your board doesn’t have same yaml that you posted here.
edit:
add option
optimistic: true
